Author Topic: Midway Start Button (what contact is what?)  (Read 1452 times)
CWorley
  • Last login:August 09, 2019, 07:44:36 pm
« on: April 07, 2012, 06:22:16 pm »
The contacts are labeled A, B, and C.  Which one is which?
dendawg
  • Last login:January 15, 2026, 08:15:21 am
Re: Midway Start Button (what contact is what?)
« Reply #1 on: April 07, 2012, 06:29:52 pm »
The contacts on a typical arcade push button microswitch are usually:
Ground/Common
Nomally Open (pressing the button closes the circuit)
Normally Closed (pressing the button opens the circuit)
Typically Ground and Normally Open are the only contacts you should need.
Testing continuity with a multimeter should help you determine which is which.
« Last Edit: April 07, 2012, 06:31:34 pm by dendawg »
Unstupid
« Reply #2 on: April 07, 2012, 11:57:12 pm »
A- Normally Open
B- Normally Closed
C- Ground/Common
A multimeter can be your best friend!  ;)
CWorley
« Reply #3 on: April 08, 2012, 09:11:04 am »
Thanks guys!
