Author Topic: help with rowe ami mm1 jukebox  (Read 3710 times)
novasarc1
  • Last login:April 04, 2012, 02:13:45 pm
« on: April 04, 2012, 02:10:27 pm »
would like to know if anyone can help me with a problem with my rowe ami mm1 the problem i have now is that the arm will not bring record to turntable i do hear the motor running but don't see gears moving any help would be appriciated also wher can a get an owners manuel for it, as well looking for graphics for it
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: help with rowe ami mm1 jukebox
« Reply #1 on: April 10, 2012, 06:13:13 am »
Hello novasarc1,
Sorry you did not leave name. You can use any Rowe Ami manual that features the 1100 mechanism, there are number of sites in the USA that you can download manuals from also a number of dealers with the manuals on CD, I prefere a manual.
More than likely the transfer motor will need replacing, on the open gearbox look at a brown fibre gear it will have some broken teeth allowing the gears to slip.
I stock good used motors but I am in the UK.
Regards
Alan Hood
ami-man
UK
ami-man
UK
