Author Topic: Need some help on sharing files between 98 & XP  (Read 1190 times)
walls83
  • beer is good
« on: September 28, 2003, 12:14:42 pm »
Ive shared files before from XP to 2000 but for some reason I cant get the computers to see each other with XP and 98.  I have the Cat5 cable connected to them but they just dont see each other.. Any advice on how to get this to work..?  Thanks
sac01
  • Last login:February 27, 2016, 08:15:22 am
Re:Need some help on sharing files between 98 & XP
« Reply #1 on: September 28, 2003, 12:37:09 pm »
The easiest way is use XP to create a network setup disk, then run the disk on the win98 machine, works great.
I'm assuming when you say you have cat5 connecting the 2 pc's, that you're either using a crosspver cable, or through a router, not just a straight piece of cat5 between the 2 network cards?
walls83
  • beer is good
« Reply #2 on: September 28, 2003, 12:47:42 pm »
Yes a crossover cable
DAmnb
  • Last login:July 28, 2011, 03:35:40 pm
  • R-Type for president!
    • TheGameCollector
« Reply #3 on: September 28, 2003, 05:47:12 pm »
One easy way is to just setup a ftp server on the xp comp and connect with the 98, if you just want to transfer files that is.
