Author Topic: MK4 25" Monitor Green is out and image is slanted  (Read 2151 times)
testicle187
  • Last login:January 24, 2026, 06:08:15 pm
« on: March 30, 2012, 08:32:16 pm »
I am not sure what would cause the green color to be out and the image to be slanted on my MK4 cabinet.  Is this something a full cap kit would fix?  Sorry if this is a bad question, I just don't know where to start.  The wires from the Jamma harness to the connector on the monitor seem fine.
MK3FAN
Re: MK4 25" Monitor Green is out and image is slanted
« Reply #1 on: March 31, 2012, 02:17:51 am »
Sounds like it's out of convergence. Pics?
grantspain
« Reply #2 on: March 31, 2012, 04:38:41 am »
or possibly yoke has slipped off home position
testicle187
« Reply #3 on: March 31, 2012, 11:37:14 am »
I will get pics up.  Do I need pics of the chassis and tube areas as well as the display?
testicle187
« Reply #4 on: March 31, 2012, 01:22:00 pm »
testicle187
« Reply #5 on: March 31, 2012, 01:24:18 pm »
More pics
testicle187
« Reply #6 on: March 31, 2012, 01:25:11 pm »
Can anyone help me identify the chassis?  I would like to send it off to get repaired, if anyone believes that is the problem...
grantspain
« Reply #7 on: March 31, 2012, 05:55:25 pm »
looks like a u5000 or u2000
anyway just looks like green drive transistor is shot-most likely broken trace or dry solder joint on neck card
testicle187
« Reply #8 on: April 01, 2012, 02:54:29 am »
How would one go about fixing this issue?  I am guessing a chassis repair and cap kit won't take care of this problem.
grantspain
« Reply #9 on: April 01, 2012, 05:06:22 am »
you would need to remove the neck card cover and check for broken tracks and then use a multimeter to check the transistor
