Author Topic: juke box amp  (Read 2005 times)
muddyoscar
  • Last login:August 10, 2021, 07:11:13 am
juke box amp
« on: March 29, 2012, 08:56:22 am »
need info on what type of amp to use in a computer juke box
Re: juke box amp
« Reply #1 on: March 29, 2012, 09:23:46 am »
You're not giving much to go on here.
Here's one that works just fine.
http://www.amazon.com/dp/B0013CDZDI/ref=asc_df_B0013CDZDI1955475?smid=ATVPDKIKX0DER&tag=hyprod-20&linkCode=asn&creative=395093&creativeASIN=B0013CDZDI&hvpos=none&hvexid=&hvnetw=g&hvrand=3163040801862951620&hvpone=&hvptwo=&hvqmt=
It kind of depends on your connections (standard stereo, optical, etc), your speakers (4ohm, 8 ohm, etc), whether you're hooking up a sub, space constraints, etc.
A number of people go with 2.1 computer speaker setup because it's easy, and generally, they sound really good.
Like this one
http://www.amazon.com/Logitech-S220-Speaker-System-Subwoofer/dp/B000RQSGYO/ref=sr_1_4?s=pc&ie=UTF8&qid=1333027190&sr=1-4
Finally, often, you'll want a separate volume control knob run to the outside of the cab somewhere. You can opt for a griffin powermate, but you can also hack the control module that came with your speakers (computer speakers typically will have one), or you can hack a mouse scrollwheel, like I did.
http://forum.arcadecontrols.com/index.php?topic=115860.msg1238038#msg1238038
