Author Topic: Arcade Invaders Cabinet (was Street Fighter)  (Read 24809 times)
Termin8tor
  • Last login:August 04, 2020, 01:54:23 am
« on: March 27, 2012, 11:20:27 am »
Just thought I'd share my plans for my upcoming full size cabinet. In the past I'd only been able to build bartops (living in a top floor Flat) but now I live in a house and with my GF's permission I can finally start my new project. I've just purchased the monitor, a 19" Samsung 4:3 in mint condition (£16.01 thanks ebay) and already have most of the components needed so things should move fairly quickly.
« Last Edit: January 20, 2013, 08:20:57 am by Termin8tor »
Sparkolicious
  • Last login:June 21, 2024, 11:49:25 pm
  • Measure twice cut once dern it!
Re: Upright 2 Player Cabinet
« Reply #1 on: March 27, 2012, 02:57:11 pm »
nice design!  :applaud:
Termin8tor
« Reply #2 on: April 02, 2012, 08:09:08 am »
Things are moving along at a steady pace. I've changed the plans slightly losing the feet and shrinking it slightly. I find the best way to build a cab is around the monitor and having a big cab and small monitor just doesn't work. I haven't decided on a theme yet, all suggestions welcome. I'm going for a 2 player 6 button set up with a coin door. ;)
Termin8tor
« Reply #3 on: April 03, 2012, 04:32:17 pm »
Small update finished the marquee area and component shelf. Rain stopped progress on cabinet, but managed to get in some game time (testing) with my son.
Termin8tor
« Reply #4 on: April 08, 2012, 07:02:53 am »
Decided on a Street Fighter theme after all. I couldn't find a decent moves strip so I made one up, what do you think?
brad808
  • Last login:May 22, 2023, 08:18:15 pm
« Reply #5 on: April 08, 2012, 10:13:02 am »
It's cool looking but not really accurate to any of the sf2 variants. If your thinking plain vanilla sf2 world warrior then you might want to remove the moves that don't apply to that game such as all the "super" moves and a lot of the moves that got introduced in later sf2 games. If you want it to be ssf2 turbo type theme then maybe try and add the other characters in somewhere. Possible around the bezel? Just my thoughts. Build is looking real good though.
Termin8tor
Re: Street Fighter 2 Cabinet
« Reply #6 on: April 08, 2012, 11:48:20 am »
Thanks for the reply I'am going for the super street fighter 2 turbo look with the other 8 characters on the bottom of the bezel.
Termin8tor
« Reply #7 on: April 10, 2012, 04:50:52 am »
First undercoat applied. First I sealed the edges of the MDF with a water+wood glue mix which works pretty well and then added the first coat, let dry overnight and sanded it with a 150grit sand paper. I will probably go with another 2 undercoats using a finer sandpaper each time and finish off with a top coat of a dark blue gloss.
Some Pics:
Termin8tor
« Reply #8 on: April 10, 2012, 05:06:20 pm »
Lexan cut for control panel, marquee and bezel.
Seith
« Reply #9 on: April 11, 2012, 05:08:46 pm »
I really like this design, although I am personally going for a variant of the Jakobud cab design... really digging the candy-esque receeded marquee.  Any reason you decided to go this route over a more traditional design?
Also, where are your speakers going?
Termin8tor
« Reply #10 on: April 11, 2012, 05:42:59 pm »
The main reason for this design was size, the whole cab stands a touch over 5ft and I didn't have a specific design in mind when I started planning I just went with what I wanted in a cab. It wasn't until I started building it that I could see the candy-esque look but also a bit of vewlix and taito in there as well. I guess this cab is inspired by all the cabs Ive seen on here and picked the things I like.
The speakers will be going under the CP area above the coin door partially out of sight with volume control in the middle.
nintendoid
  • Last login:January 16, 2024, 03:49:20 pm
    • Nintendoid
« Reply #11 on: April 17, 2012, 04:59:53 am »
have you tried CPS2shock... they have a lot of Street Fighter and also other fighter games artwork, perhaps you could mimic one of these styles for the main game you want to play on the cabinet.
Termin8tor
« Reply #12 on: April 18, 2012, 01:57:50 pm »
Eureka  ;D. I bought a coin mech off ebay one that copies the coin in the mech but it just wasn't what I wanted, so after some research I bought a mars ms111 (eBay) and quattro 1 credit board (http://www.andysarcade.net/) hooked them up to my bartop and bingo worked first time. Now 20p gives me 1 credit, 50p-3 credits and £1-7 credits.
Termin8tor
Re: Street Fighter 2 Player Cabinet
« Reply #13 on: April 23, 2012, 04:19:05 pm »
Small update. Ive fitted the coin door, applied the top coat of paint (white gloss) and worked on some of the internals.
Termin8tor
Re: Street Fighter? 2 Player Cabinet
« Reply #14 on: April 24, 2012, 02:28:47 pm »
Fitted the screen today and wired up the speakers. All internals motherboard, HDD and video card are working as they should and didn't take much time as I stripped them out of my first build (weecade clone). Didn't see the point of keeping it as it probably would just sit there gathering dust. Once my son came home from school he tested it out for me, at the time of writing this its been on for about 6 hours so guess that will do. Things to do next week: speaker covers, fit joysticks and buttons, design print marquee + CP, fit light in marquee area. I have spare cathode lights but like results people are getting using LED's so unsure.
Some pics (buttons and Marquee are temporary)
« Last Edit: April 24, 2012, 04:41:23 pm by Termin8tor »
Louis Tully
« Reply #15 on: April 24, 2012, 03:49:17 pm »
« Last Edit: February 12, 2015, 05:42:44 am by Louis Tully »
Termin8tor
« Reply #16 on: April 29, 2012, 02:26:17 pm »
Update time. Today I managed to drill button holes,get the joysticks and buttons mounted and wired up, print out CP and marquee and now I have a fully functional coin mech  ;D.
Tomorrow's plan is to install marquee light, tidy up wiring and make a start on the back depending on the weather. But I'll probably just spend the day playing Street Fighter  ;)
Update Pic:
SNAAKE
  • Trade Count: (+29)
  • Last login:October 23, 2025, 06:48:22 pm
« Reply #17 on: April 29, 2012, 03:15:26 pm »
neat :applaud:
pharoah007
  • Last login:June 29, 2017, 07:27:26 pm
  • Why buy it when you can BUILD it!
« Reply #18 on: April 29, 2012, 04:58:15 pm »
Lookin REAL good man.  I like the way you incorporated the Rooftop from Ryu's stage in the CP and Marquee.
good job!
« Reply #19 on: April 29, 2012, 07:51:34 pm »
Update Pic:
You know, I'm usually not a fan of anything other than the old-fashioned boxy arcade cabinet, but yours turned out really nice. Good job!!!
Termin8tor
« Reply #20 on: April 30, 2012, 04:02:25 am »
neat :applaud:
good job!
Thanks.
I agree, inspiration came from a 1975 Jet Fighter cabinet.
« Last Edit: April 30, 2012, 07:30:25 am by Termin8tor »
nintendoid
    • Nintendoid
« Reply #21 on: May 01, 2012, 05:51:30 am »
its nice to see another Street Fighter cabinet :)
cant get enough of a good game :)
Termin8tor
« Reply #22 on: May 02, 2012, 02:38:17 am »
Small update......Speaker grills,marquee light, instruction card,credit label added and secured control panel.
« Last Edit: May 03, 2012, 03:03:21 pm by Termin8tor »
kalars123
  • Last login:August 09, 2019, 12:31:51 pm
« Reply #23 on: May 02, 2012, 01:13:51 pm »
loving the workmanship just a little torn on the design it looks great just.... awkward to me i guess either way GREAT WORK!
  • Last login:July 23, 2025, 07:04:20 pm
« Reply #24 on: May 02, 2012, 01:27:47 pm »
I like that marquee
Louis Tully
« Reply #25 on: May 02, 2012, 04:05:14 pm »
« Last Edit: February 12, 2015, 05:43:59 am by Louis Tully »
Termin8tor
« Reply #26 on: May 07, 2012, 08:04:02 am »
Revised plans added to first post.
racecar
  • Last login:June 29, 2012, 01:36:27 am
« Reply #27 on: May 07, 2012, 11:09:36 pm »
Great looking cab! Nice Design also
Termin8tor
« Reply #28 on: May 09, 2012, 01:38:27 pm »
99% completed. Just need to sort out some of the emulators and games. Here are the final pics:
jammin0
Re: Street Fighter 2 Player Cabinet (Completed)
« Reply #29 on: May 09, 2012, 04:34:43 pm »
nice and sleek, I really like it
Termin8tor
Re: Arcade Invaders Cabinet (was Street Fighter)
« Reply #30 on: January 20, 2013, 08:24:09 am »
Changed Joysticks from Magsticks to balltops after using balltops in my last bartop build and found them much better IMHO. Also changed the artwork while I was at it.
« Last Edit: January 20, 2013, 08:44:02 am by Termin8tor »
HollowPointAMG
  • Last login:January 30, 2013, 07:14:39 am
« Reply #31 on: January 20, 2013, 08:56:27 am »
Love the design too!  I like the Arcade Invaders artwork better.  Matches the entire design.
Phase 1: Design
Louis Tully
« Reply #32 on: January 20, 2013, 10:42:03 am »
« Last Edit: February 12, 2015, 03:15:46 pm by Louis Tully »
Termin8tor
« Reply #33 on: January 25, 2013, 05:44:32 pm »
I thought it was pretty badass when it was a SF cab. The new artwork/balltops look solid though. Very, very clean. Hits the "less is more" dead on, imo.  :cheers:
Thanks for the feedback guys.  :cheers:
