Author Topic: Rockola 445 problems!  (Read 4095 times)
ronnie-dent
  • Last login:May 15, 2020, 09:42:50 am
« on: March 21, 2012, 02:31:23 pm »
Just picked this up today, has a couple of faults, turntable spinning too slow and some selection problems? only a certain amount of records it will find, just thought I would ask the questions before I look it over properly
thanks for any help
johncw
  • Newbie
  • Last login:May 04, 2012, 04:45:50 am
Re: Rockola 445 problems!
« Reply #1 on: May 04, 2012, 04:27:08 am »
Hello, Ronnie, suggest you check the turntable motor rubber grommets, they perish after about 20 years.  The motor drops, and the idler runs on the top 33-1/3 step of the motor shaft, instead of the lower 45 step!  New ones are less than £1 each.  Selection, clean the printed track both sides of the selector plate.  Be VERY careful of the wipers, they have been known to go brittle with age and break off !  Use IPA or switch cleaner, NOT WD40!  If well tarnished, use Brasso or Dura-glit, then IPA.
John, Bristol.
ronnie-dent
« Reply #2 on: May 06, 2012, 09:05:58 am »
John, Bristol.
Thanks John, I got the grommets done a while back, just need to clean the selection switches contacts, have bought some switch contact cleaner but I'm working on other things just now, thanks Ronnie
