Author Topic: Need help repairing my Model 1 Genesis  (Read 1732 times)
shess
  • Last login:January 07, 2021, 04:17:28 pm
« on: March 20, 2012, 01:16:17 pm »
I've got a Model 1 Genesis with "High Definition Graphics" around the bezel and the s-video mod.  It was working fine after the mod and then I let it sit around for a couple months.  When I went back to it, it would power up, but nothing came on the screen.  I cleaned the cartridge (multiple games), then tried putting alcohol liberally on the contacts and inserting/reinserting it a bunch in the console.  I also tried the credit card+400grit sandpaper trick followed by more alcohol cleaning and it still won't work.  I'd rather not have to mod another Genesis so what else can I check on this one?
SavannahLion
Re: Need help repairing my Model 1 Genesis
« Reply #1 on: March 20, 2012, 02:28:33 pm »
Stop sanding the contacts to start with. I only ever cleaned my slot once and I was young and stupid then. IIRC, the contacts are self wiping so unless you stored your Gennie in absolute filth, they'll be OK.
I would move into checking the mod you've done. A bad solder or broken wire could cause your problem.
northerngames
  • Trade Count: (+18)
« Reply #2 on: March 20, 2012, 05:04:15 pm »
yeah uh I dunno where the 400 grit came in but that's probably the problem as it more then likely damaged a few traces guy  :cheers:
« Last Edit: March 20, 2012, 05:06:54 pm by northerngames »
shess
« Reply #3 on: March 21, 2012, 01:08:49 pm »
When I searched for all the ways to clean the slot I came across this, http://www.ifixit.com/Guide/Cleaning-the-Game-Port/3771/1 , among others.  I'll check out my s-video mod and see if anything broke.
