Author Topic: I-Pac vs. J-Pac Custom Build Question  (Read 1333 times)
micahman33
  • Last login:September 04, 2024, 03:56:19 pm
« on: March 14, 2012, 09:10:47 am »
First off, thanks to everyone who has been contributing...there is some phenomenal information floating around here. That said, one thing I remain confused about it whether I need the I-Pac or J-Pac for a totally custom build I am doing. Not working from an existing machine or anything, and only need two players. Does the type of joystick I get dictate whether I need I-Pac or J-Pac or is it all irrelevant since Im not working from a cabinet with already existing components? Ive searched around and tried to see if anyone had similar questions but didn't see anything. Thanks
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: I-Pac vs. J-Pac Custom Build Question
« Reply #1 on: March 14, 2012, 09:15:40 am »
The JPac is designed to be plugged into a cabinet that is wired JAMMA, which most often occurs when using an existing cabinet (although some, like me, prefer to wire a cabinet as JAMMA to provide more flexibility down the road, such as being able to plug in a real game board).
If you aren't going to wire your cab JAMMA, then you don't want a JPac.
Working: Not Enough
Projects: Too Many
Progress: None
micahman33
« Reply #2 on: March 14, 2012, 09:22:22 am »
Awesome. Thanks so much for your help. I was holding off on ordering joysticks/I-Pac until I knew for sure the two would play well together, but it sounds like I should be good to go. Looking to start with some basic HAPP Competition joysticks and go from there once I really get into this.
