Author Topic: Restoration questions  (Read 2984 times)
Uncle Monkey
  • Last login:September 12, 2020, 10:16:25 pm
  • P24L
    • Project Thread
« on: February 27, 2012, 11:40:57 pm »
So....I'm almost finished with my MAME cab, and I'm interested in a new project maybe, but I have no clue how the old machines work. So basically I'm wondering, what would it take to build a machine from a JAMMA PCB board?
matsadona
Re: Restoration questions
« Reply #1 on: February 29, 2012, 07:27:15 am »
If you have the PCB, you will need:
* some wires (just search Ebay for JAMMA harness)
* buttons and joysticks
* a 15kHz monitor (an ordinary TV can be used)
* power supply (+5V, +12V and sometimes you also need -5V, once again Ebay is your friend)
* 8Ohm speaker(s)
The rest is optional like coin door, wood, paint, t-mold and all that other stuff that makes a great cabinet.
  • Last login:January 22, 2026, 12:55:00 pm
« Reply #2 on: February 29, 2012, 03:14:31 pm »
* 8Ohm speaker(s)
An ordinary TV cannot be used, unless you have a converter wired-in to change the 15khz video signal coming off your jamma PCB to 31khz which what TVs and LCD Monitors use.
For power, you'll need more than just a switching power supply, and this will vary depending on what monitor you're going to use. If you're going with a real arcade monitor, you'll need a isolated power block that will distribute power to the monitor and switching PS.
Take a look at these two links for basic info on wiring up Jamma:
http://www.therealbobroberts.net/acwiring.html
http://www.therealbobroberts.net/jh.html
matsadona
« Reply #3 on: March 01, 2012, 06:30:47 am »
With ordinary TV I was referring to an old CRT TV as an option to more expensive ”arcade monitors” assuming that you would like to have a CRT screen for this kind of project, not any LCD. Maybe I should have stated that more precisely.
If you live in the US and can’t find any SCART/RGB equipped TV you need a RGB to Composite converter as well. I tend to forget that since I live in Europe.
The “arcade monitors” requires transformers etc as you say but doesn’t require anything that converts the video signal.
matsadona
« Reply #4 on: March 01, 2012, 07:33:08 am »
I have done this kind of project a while ago, and it is partly documented in a separate thread here:
http://forum.arcadecontrols.com/index.php?topic=105790.0
And the parts I used is basically what I listed before:
* an old 14” CRT TV
* a jamma harness
* a joystick and some buttons
* an arcade PSU
* two 4 Ohm speakers wired in series
