February 04, 2026, 04:36:13 am
Try adjusting your height down a bit. And, yes, adjusting the 50/60Hz pot should have SOME effect on screen.
Quote from: SirPeale on March 21, 2012, 03:19:15 amTry adjusting your height down a bit. And, yes, adjusting the 50/60Hz pot should have SOME effect on screen. yes adusting the pot should make the foldover worse or cure it. if it's doing nothing, maybe the pot is damaged.
