Author Topic: Power for Aimtrack IR Sensor Bar  (Read 2032 times)
LASooner
  • Last login:July 06, 2025, 08:09:32 pm
« on: February 18, 2012, 04:39:21 am »
Does the IR sensor for the LCD lightgun need to be plugged into the computer? Would a USB wall charger supply the power it needs? Just curious if anyone has tried this.
One less thing pulling juice from the computer would be nice.
romshark
  • Last login:October 16, 2023, 02:50:59 pm
  • Arcade and Robotics enthusiast
Re: Power for Aimtrack IR Sensor Bar
« Reply #1 on: February 18, 2012, 07:32:52 am »
Yeah, a wall charger type works. I use it in mine, so I can use the Wii with my cabinet without turning on the computer part.
SammyWI
« Reply #2 on: February 18, 2012, 08:04:02 am »
It just needs USB power not any link to the computer.  A usb charger should work fine.  I have used the USB hub built into a monitor without linking the monitor hub back to the PC with any USB cable.
05SRT4
  • Check out my Pow Pow
« Reply #3 on: February 18, 2012, 11:20:50 am »
Is the only reason why you would need a PC is for the grain change?
LASooner
« Reply #4 on: February 18, 2012, 03:01:20 pm »
Thanks guys.
lettuce
  • Make It So!
« Reply #5 on: February 18, 2012, 05:06:40 pm »
Would a 3rd party wireless Wii sensor bar work with the AimTrak lightgun??
DarthMarino
  • Last login:September 06, 2025, 02:38:47 pm
« Reply #6 on: February 18, 2012, 05:19:35 pm »
No. It's a different layout on the IR lights.
romshark
« Reply #7 on: February 18, 2012, 10:48:11 pm »
However, the Wiimote works very well with the AimTrak sensor bar.
matsadona
« Reply #8 on: February 20, 2012, 07:10:06 am »
Anything normally powered through USB is 5V with a maximum 500 mA current*. So anything with that specs can be used as an alternate power source.
Note that it has to be 5 Volt, but the current rating could be higher. The circuit will not be “charged” with a 3A current if the power supply rating says 5V / 3A. That only means that the power supply can deliver a current of 3A.
Something like if you buy a $5 item with a $100 bill, you will not be charged $100, just the $5 ;)
* There is USB equipment that has double connectors, and that is simply because the total current need is more than 500mA.
