Author Topic: Sanwa 29E31S Gradual Screen Swell  (Read 4062 times)
Jollywest
  • Last login:Today at 08:50:48 am
« on: February 18, 2012, 03:11:52 am »
Hi,
I've noticed a bit of an issue with the Sanwa 29E31S Arcade monitor I'm using. Its not a massive issue and everything else works great apart the screen size gradually gets bigger both vertically and horizontally. After about an hour the Windows taskbar has just about disappeared and its not just the screen position moving down its cropped on every side. Turning the monitor off and back on resets the screen to the correct size. Any ideas?
Thanks.
grantspain
Re: Sanwa 29E31S Gradual Screen Swell
« Reply #1 on: February 18, 2012, 12:36:57 pm »
sounds capacitor related-most likely a couple of the 22uf 250v caps a bit leaky
Jollywest
« Reply #2 on: February 18, 2012, 12:47:00 pm »
Cheers Grant, I'll have a look at those caps.
Jollywest
« Reply #3 on: July 30, 2019, 08:10:22 am »
Ok huge bump from the grave I know but I recently had a few other issues with this monitor so finally got round to doing a cap kit on it.
After replacing the caps all the more recent problems have been fixed, but the gradual screen swell issue is still there... again it’s not a massive problem but any idea what else it might be please?
I’m on the lookout for a remote board, just to rule out it isn’t causing the problem.
grantspain
« Reply #4 on: July 30, 2019, 09:46:35 am »
do you lose control of the pincushion?
Jollywest
« Reply #5 on: July 30, 2019, 10:19:00 am »
I did have Pincushion issues before doing the cap kit, it’s fine now though
grantspain
« Reply #6 on: July 30, 2019, 10:27:21 am »
if the picture is not going super wide and loses pincushion control then it sounds like bad pot or bad connection on remote board
if it was doing both those things it would be flyback failing
Jollywest
« Reply #7 on: July 30, 2019, 10:31:28 am »
Ok great thanks Grant... hopefully I can find another remote board then or fix mine
« Last Edit: July 30, 2019, 10:33:06 am by Jollywest »
