Author Topic: Tempest Problem  (Read 1237 times)
vishwats
  • Last login:August 10, 2004, 08:43:43 pm
  • No! Iam an Alpaca
    • Vishwa.net
Tempest Problem
« on: September 24, 2003, 11:37:51 am »
HI,
I am using Pure DOS and DMAME with Advmenu front end.
When I select tempest from Advance menu, I get an error saying I don't have a VESA card or my video card does not support the required resolution.
When I run mame through the command line
d:\mame tempest -800x600, it works fine for me.
How do I setup advancemane to pass the required parameter so when it launches mame with tempest it uses the resolution parameter.
So is there any way I can configure mame to launch at a particular resolution whenever I launch tempest. ?
-vishwa
Malachai
  • Last login:April 05, 2014, 11:07:00 pm
Re:Tempest Problem
« Reply #1 on: September 29, 2003, 09:51:52 am »
In the Windows build, you can set the resolution in the MAME.ini file.  Not sure about the DOS build, but it's worth a look.
