Author Topic: Utrak doesn't move straight.  (Read 1860 times)
monkey puzzle
  • Last login:March 23, 2024, 02:11:59 pm
« on: February 11, 2012, 05:41:05 pm »
I just fitted and connected my Ultimarc trackball to my cp. Everything seemed to work ok, but then I noticed that if I use it to move the mouse pointer something strange happens. If I spin the ball fast upwards, the pointer moves staight upwards, but then curls off to the left before it stops. Similarily, when I spin the ball in another direction, the pointer seems to follow a similar curved path. If I roll the ball slowly it moves in a perfect straight line.
I haven't tried using the ball in a game yet, so I don't know if this would effect gameplay. I just want to know if this is normal. I haven't contacted Ultimarc yet because I'm not sure if this is a problem or not. Has anybody else experienced anything like this?
  • Last login:Yesterday at 11:23:23 pm
Re: Utrak doesn't move straight.
« Reply #1 on: February 11, 2012, 06:22:43 pm »
You need to give it some time to break it in.
SammyWI
« Reply #2 on: February 11, 2012, 07:51:42 pm »
I don't recall if my Utrak curved like you describe but it defiantly was a bit 'clunky' when I first got it.  It would jump or clunk when spun fast.  It breaks in fairly quickly and is smooth now.
monkey puzzle
« Reply #3 on: February 11, 2012, 08:14:21 pm »
Ok thanks, I'll give it some time.
I wonder what it is that actually "breaks in". Is it the bearings maybe?
taylormadelv
  • Last login:February 18, 2019, 05:46:59 pm
« Reply #4 on: February 12, 2012, 08:42:49 am »
My Utrack was perfect out of the box... Maybe you can take it apart and reseat the bearings. It should roll perfectly smooth...
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #5 on: February 12, 2012, 05:02:15 pm »
Its the stainless steel rollers. At first they have microscopic machining marks on the surface. These are accentuated after a few minues use, at the point of contact with the ball,  but after a longer time, maybe 30 minutes of use, the marks wear down to a smooth, slightly dished curved groove in the rollers.
