Author Topic: Arcade cabinet caster  (Read 5540 times)
lagourich
  • Last login:March 06, 2012, 02:09:39 pm
« on: February 10, 2012, 09:38:29 am »
Hello all,
I'm currently working on my very first Galaga arcade cabinet and I would like to setup casters in order to move it more easily.
The idea is to hide two angle wheels at the bottom back, so that it can be moved by laying down the cabinet at 45°.
I found the casters of my dreams on eBay, unfortunately it can't be delivered outside US and I live in Europe...
Any idea where I can found these, or alternate suggestions ?
Picture below:
Re: Arcade cabinet caster
« Reply #1 on: February 10, 2012, 09:50:27 am »
http://www.arcadeshop.de/Accessories-Cabinet-Wheel-3_803.html
Personally, I don't think wheels help all that much when it comes to moving an arcade cabinet. It feels like the cab is going to get away from me when moving one with the wheels. I use a furniture dolly, makes things a lot easier to control.
« Last Edit: February 10, 2012, 09:52:46 am by Nephasth »
elkameleon
« Reply #2 on: February 10, 2012, 09:51:47 am »
Those are awesome!
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #3 on: February 10, 2012, 02:50:38 pm »
If you can't get those exact ones you can replicate the same way they sit by simply mounting normal fixed castors inside your machine at a 45 degree angle panel, and simply cut a hole for the wheel to protrude through - easy!
Afterburner
  • Last login:July 27, 2016, 01:02:00 am
« Reply #4 on: February 10, 2012, 07:15:18 pm »
I just mounted castering wheels to the bottom of my cab so it would be easy to move.  Of course, they don't work all that well on the carpet, but at least the cab doesn't move around during...err....vigorous play.
  2-player upright dual trackball / dual 8-way rotary joysticks - built from scratch
Turnarcades
    • Turnarcades
« Reply #5 on: February 11, 2012, 01:39:36 pm »
We do too. We build a square timber frame with MDF top panel for the base, which sits just up inside. Mounting the castors on the MDF part of the base then means its fully upright and movable, but does not stand high up on visible wheels.
lagourich
« Reply #6 on: February 13, 2012, 05:02:45 am »
Thanks a lot for this web site, exactly what I was looking for!
I'll try to adapt these casters on my cabinet (doesn't need to be moved to often anyway) and I will let you know the result :-)
