Author Topic: Painting MDO  (Read 2267 times)
GregD
  • Last login:December 19, 2024, 04:27:31 pm
    • Arcade Nebula
Painting MDO
« on: February 09, 2012, 11:59:06 am »
Looking for some advice.  The components of my cabinet are cut out of MDO and I am looking for the best method to paint it.  I see that many use foam rollers for this job.  What is the best technique for getting a smooth coat with as little texture as possible?  Should I be thinning the paint?  What type of paint and what type of primer should be used?  Latex or oil?  Gloss or Semi Gloss?  I googled painting methods for MDO and the replies were from exterior sign makers that used some $pecialty paint.  I have no problem purchasing good paint but it should be available off the shelf at Big orange or Sherwin Williams, etc.  I do have an HVLP spray kit but everytime I have painted with it I have gotten the orange peel results even when using Flotrol to thin.  Anyone have a tried and true method?  Thanks in advance.
Dervacumen
  • Last login:June 12, 2024, 01:58:21 am
  • Home of Three Squares dice game
    • Beaker Games
Re: Painting MDO
« Reply #1 on: February 09, 2012, 06:06:19 pm »
Maybe check out this thread.  It's full of a bunch of gobbledegook about painting.  I didn't follow those instructions, and ended up with very light roller bumps.  Next time I'll follow these instructions.  The overlay on MDO must be very similar to MDF, no?
Bringing to life a child's imagination.
GregD
    • Arcade Nebula
Re: Painting MDO
« Reply #2 on: February 09, 2012, 08:33:53 pm »
MDO has a paper overlay that takes paint really well.  It is also kind of expensive so I do not want to mess it up.  I dont see a link in your post.  Thanks
Nevermind. I see it now
  • Last login:Yesterday at 03:54:42 am
Re: Painting MDO
« Reply #3 on: February 09, 2012, 09:19:16 pm »
I've had pretty good results using my painting method, you can find details here (scroll down the page to a step by step guide):
http://forum.arcadecontrols.com/index.php?topic=88912.960
GregD
    • Arcade Nebula
Re: Painting MDO
« Reply #4 on: February 16, 2012, 02:20:07 pm »
So, what would work best?  Oil or latex?  I would prefer to use latex but if the results will be significantly better with oil based then I will do that.
Dervacumen
    • Beaker Games
Re: Painting MDO
« Reply #5 on: February 22, 2012, 02:37:13 pm »
Just follow what Ond does, if you can.  You'll get excellent results.
