Author Topic: Specs for emulation box  (Read 1405 times)
starwarsfan54321
  • Last login:October 26, 2017, 04:40:26 pm
« on: February 08, 2012, 05:43:40 pm »
I recently wanted to build a emulation box after I finish my first arcade cab, does anyone have any ideas for specs I would need to emulate the N64 or Dreamcast, if there is a big jump in specs from the N64 to Dreamcast, I do not need to have the Dreamcast.
ark_ader
  • I glow in the dark.
Re: Specs for emulation box
« Reply #1 on: February 08, 2012, 06:48:16 pm »
I used to mess about with emulating consoles, especially the dreamcast.  I found that it was a losing game, so I just use the real thing.
I guess it depends on the games you want to play.  I have only a 5 so disc swaps are not so a chore.
Anything earlier is just hit and miss (and tweak).
Green Giant
« Reply #2 on: February 08, 2012, 06:49:14 pm »
Can you break down exactly what an emulation box is.
Is this a computer that is designed to only run emulators for consoles?  Possibly in cabinet or small form factor?
Toxic Arcade, my first build
« Reply #3 on: February 08, 2012, 07:18:49 pm »
Yep, pretty much.
I did one of these....it was primarily for older games though.....It could handle most N64, games like perfect dark were choppy and slow, but Zelda Ocarina played perfect.
http://forum.arcadecontrols.com/index.php?topic=107220.0
I bet that the one that Burgerking Diamond did would be able to handle DC and the likes of that, he had higher specs on his computer.
http://forum.arcadecontrols.com/index.php?topic=105479.0
