Author Topic: Lighting Paradise Arcade LED Lighted Arcade Pushbuttons  (Read 4635 times)
daillest319
  • Last login:April 04, 2012, 08:48:41 am
« on: February 06, 2012, 02:18:06 pm »
Anyone have any idea how i would light these. i am a noob in this area i purchased 16 buttons. I placed two links below of the buttons and a power supply i purchased but i have no idea what wires i would need and how i would connect them to light the buttons.
Also for the buttons details i purchased the 75 gram cherry microswitch and voltage for all the buttons is 5v.
http://www.paradisearcadeshop.com/en/230-red-led-convex-arcade-pushbutton.html
http://www.paradisearcadeshop.com/en/electrical/4-arcade-switching-power-supply.html
matsadona
Re: Lighting Paradise Arcade LED Lighted Arcade Pushbuttons
« Reply #1 on: February 15, 2012, 05:27:15 am »
Regardless if it is an actual arcade or MAME cabinet there should be a 12V power supply present. You don’t need an additional PSU just to light the buttons.
Just connect +12V and GND to the correct connectors at the button LED’s and you’ll be fine 
BobA
  • What Me Worry?
« Reply #2 on: February 18, 2012, 09:03:09 am »
Danger Will Robinson!
He purchased 5V buttons so connect to 5V and ground NOT 12V.
« Last Edit: February 18, 2012, 09:05:54 am by BobA »
matsadona
« Reply #3 on: February 20, 2012, 05:06:58 am »
I'm pretty sure the webpage linked to above stated that the LED's are 12V, but I can't verify that right now since the server seems to be down.
But if it is 5V LED's connecting them to 12V would be a bad idea for sure. So my bad missing that comment.
matsadona
« Reply #4 on: February 21, 2012, 05:02:43 am »
Quoted from the webpage:
These convex buttons come complete with same color 12V LED's and arcade standard 50 gram microswitches, ready to go out of the box!
So that is what I referred to.
The thing I didn't see, was the dropdown box were you are able to choose a 5V variant.
Anyway, the general answer persists. There should be a power source already (regardless if it is a MAME PC or JAMMA cabinet) with 5V DC. So you shouldn't need a separate PSU just to lit up the LED's.
« Last Edit: February 21, 2012, 05:22:39 am by matsadona »
« Reply #5 on: February 21, 2012, 05:21:08 am »
Also on that page is "Product Options" where you can select either 5V or 12V...
matsadona
« Reply #6 on: February 21, 2012, 05:23:52 am »
Just realized that and updated my post... sorry.
