Author Topic: Help. Windows XP Resolution Issue  (Read 4606 times)
C4N3
  • Last login:April 18, 2012, 09:25:10 am
« on: February 03, 2012, 04:06:54 pm »
Greetings Experts,
I am converting an existing cab to MAME. The cabinet has a 25in WG Arcade Monitor that is capable of 640 x 480. I have an ATI graphics card and I've applied Soft15khz. The problem I'm having is that everytime I boot up, Windows XP defaults to 800 x 600 which cause the screen on the monitor to distort. Any suggestions or directions to FORCE windows XP to boot at 640 x 480 without disabling the graphics driver, which I will need to emulate?
I'm using a JPAC to connect to the display and Hyperspin is my FE. Any help would be appreciated. Thanks again!
Ansa89
  • Last login:December 09, 2016, 10:40:11 am
Re: Help. Windows XP Resolution Issue
« Reply #1 on: February 05, 2012, 03:48:01 am »
Well, since this is the "Linux" forum, the answer is:
put you hard disk into the microwave for about 10 minutes at full power, then buy a new hard disk and install linux :laugh2: .
Seriously: imho this is not the best place where ask your question.
Earth could be the hell of another world
C4N3
« Reply #2 on: February 06, 2012, 05:00:36 pm »
Yeah, I really didn't realize I posted this in the linux forum... I thought I was in the one above this. Oops.
dmarcum99
  • Last login:January 21, 2020, 12:02:36 am
« Reply #3 on: February 08, 2012, 11:29:53 pm »
download Calamity's EMU CRT drivers if you are using the right ATI card.  Check out the goovymame forum and check it out.  Download the appropriate drivers for your card/OS (32/64bit) and go from there.
His drivers are excellent and if you research enough in the groovymame forum, you may find yourself ditching soft15khz/mame for Calamity's drivers and groovymame with Hyperspin.
Good luck!
