Author Topic: Options for hooking up trackball to my pc  (Read 2752 times)
xmrkite
  • Last login:April 22, 2012, 11:44:19 am
« on: February 02, 2012, 07:10:28 pm »
Hello all, what are my options for hooking up a trackball to my pc? I am on a tight budget on this one and want to get a 3" trackball and hook it up for mame.
Any ideas?
-Thanks
GregD
  • Last login:December 19, 2024, 04:27:31 pm
    • Arcade Nebula
Re: Options for hooking up trackball to my pc
« Reply #1 on: February 02, 2012, 09:15:18 pm »
There are numerous options for a 3" trackball.  They can be purchased new from many different vendors including Ultimarc, Groovy Game Gear, Twisted Quarter, and X gaming.  Some come with a built in interface so they can be plugged in via usb or ps2.  Some need an external interface like Groovy Game Gear's optiwiz.  There are some lower cost 2 1/4" teackballs if you just want to use it outside of an arcade cabinet.  I got my Happ 3" trackball via an ebay auction for $10.  I needed to pirchase a $15 optiwiz to interface it to my pc.  You could always hack a mouse and use the optical interdace as well but for $15 for the optiwiz it wasn't worth my time.
xmrkite
« Reply #2 on: February 03, 2012, 11:04:27 am »
OK, i bought one on ebay, a used happ one and then i bought an optiwiz. Will post back when I get it all hooked up.
-Thanks
xmrkite
« Reply #3 on: February 17, 2012, 11:45:58 pm »
OK, so I got my trackball and opti-wiz and am wondering what you guys recommend. I am not sure how to hook the two up together. Why would they sell this thing without the cable needed? I got the non-solder version. Is there some cable I can make/buy for it?
-Thanks
BobA
  • What Me Worry?
« Reply #4 on: February 26, 2012, 01:23:11 am »
There is a cable sold to connect your TB.
Cable
Garza
  • Last login:July 09, 2015, 10:53:29 am
« Reply #5 on: March 06, 2012, 11:20:39 pm »
I wired up my own original arcade track ball with a little searching >http://www.jammaboards.com/guides/TRACKBALL_INTERFACE_WIRING_KIT.pdf< go to this web site it will give you the diagram you will need to wire up your track ball to the optipac. Also there is a not as graphic wiring diagram on ultimarc for wiring up the two. Also I used just cat 6 cable and a six pin molex connector connecting the two for ease of removal if need be. I wired up the 2 black ground and the to red wires each in one slot so you would have 2 red in one molex slot and 2 black in one molex slot then 1 yellow, 1 brown, 1 green, and one blue. On the other side of the molex connector I put in six of the cat 6 wires in and ran that to my optipac. Really easy. Let me know if you need more explanation I can help if you need it. Good luck and always have fun!
