Author Topic: Vectorizing Artwork  (Read 2543 times)
Hammerheadx
  • Last login:October 26, 2014, 03:29:12 pm
Vectorizing Artwork
« on: January 27, 2012, 12:25:42 am »
Hello all, I'm new to this site but have been following some threads about artwork.
I'm taking a stab at vectorizing some pinball artwork, and have been cutting my teeth on playfield insert decals for starters.  Looking for some advice, assistance, critiques of my work so far.  Since I don;t own these games I'm having issues with determining the correct scale.
I'm attaching some playfield insert decals for F-14 Tomcat for starters - hopefully I won't get sued.
Let me know what you think - any comments are appreciated!
"Did you feed the coordinates into the computer Penfold?"
"Yes Chief, and I distinctly heard it say 'Yum, Yum'!"
Vids:  Ms. Pac Man
Pins:
Hammerheadx
Re: Vectorizing Artwork
« Reply #1 on: January 30, 2012, 12:49:16 pm »
No critiques?  No issues?  No comments?
Damn, I must be better than I thought!!  ;)
Vids:  Ms. Pac Man
Pins:
elkameleon
« Reply #2 on: January 30, 2012, 01:10:46 pm »
When I zoom in I can totally tell you radiuses aren't tangent... but i'm a picky ---uvula--- too. The points on the arrows arent perfectly round, they have a "kink" in the tip, that's the best word to describe it I guess. Just my two cents.
« Reply #3 on: January 30, 2012, 01:21:15 pm »
+1
It's all stuff that won't really be noticeable unless you are looking for it, for the most part it is really good. When I zoom in I notice tiny issues. With the radar target, the little tic marks are slightly crooked.
And I know those kinks can be a pain ironing out if you are not a pro. I wish I was better at illustrator to give good advice on how to fix it. I just always end up spending a looooong time adjusting the angles.
elkameleon
« Reply #4 on: January 30, 2012, 01:46:40 pm »
+1
Yeah, Illustrator can be a real PITA, I use SolidWorks to draw alot of my basic shapes and lines, cause I can dimension everything individually so I know its right. Then I save it out as an ai file and do my work in Illustrator.
« Reply #5 on: January 30, 2012, 01:50:28 pm »
With the radar tics, if you hold down shift while drawing the line, it should lock it to a straight line.
