Author Topic: WTB: 27-29" MONITOR BRACKETS  (Read 1311 times)
dmarcum99
  • Last login:January 21, 2020, 12:02:36 am
« on: January 23, 2012, 03:46:50 am »
I have a NEC XM-29 de-cased and inside a Midway upright(NBA JAM) for my mame cab.  I'm about to trade it, but I'm worried the plywood boards I cut as monitor mounting brackets will be too weak for travel.
If anyone has a busted 27"-29" tube, would you be willing to part with the mounting brackets so I could mount this securely?
redbeard30
  • Last login:November 23, 2023, 10:32:16 am
Re: WTB: 27-29" MONITOR BRACKETS
« Reply #1 on: February 05, 2012, 09:28:11 am »
i have a set of 27" mounts from an IT Golden Tee cab I will be removing soon. Will they work?
dmarcum99
« Reply #2 on: February 06, 2012, 02:55:08 am »
hopefully we're talking about the same item.  The bars on the monitor frame that allows you to install in the cab:
redbeard30
« Reply #3 on: February 06, 2012, 05:36:12 am »
Nope... Sorry,  i have the bars with the studs  that your pic mounts too.  Sorry!
Dragonman73
  • Last login:April 08, 2018, 07:48:01 pm
« Reply #4 on: February 09, 2012, 07:43:03 am »
Check here ---------->   http://thearcadeboneyard.com/
It's where I got mine when I converted a 25" TV
