Author Topic: Advice on frontend and O.S.  (Read 1145 times)
PedroSilva
  • Last login:August 01, 2018, 08:37:57 am
  • Grettings !
« on: September 22, 2003, 08:32:33 am »
Hi guys,
I've seen a lot of frontends for mame, but I'm unable to chose ..
Knowing that I want it:
- to be fully automatic from the switch on of the pc till the games options appear;
- to be the most bug free;
- to show some screenshoots of the game (or video):
- to have only the options up, down and go (start);
- to be able to be configured for the start of games (game by game or default);
- to be able to play mostly the old classics (80's and 90's);
I'de like you guys with experience to advise me on wht to chose regarding O.S. and frontend.
Thanks,
Re:Advice on frontend and O.S.
« Reply #1 on: September 22, 2003, 02:02:25 pm »
1- to be fully automatic from the switch on of the pc till the games options appear;
2- to be the most bug free;
3- to show some screenshoots of the game (or video):
4- to have only the options up, down and go (start);
5- to be able to be configured for the start of games (game by game or default);
6- to be able to play mostly the old classics (80's and 90's);
OK, your spec is not altogether clear, but here goes:
1- This is up to you to setup your OS to lanch the FE from startup
2- You'll have to decide this for yourself - remember they are free ;)
3- All FE's can do this (screenshots anyway)
4- All FE's featured in the <Software section can do this
5- Not sure what you mean, but generally the Windozy (non-cab) FE's allow you to setup INI's for each game
6- This ability is dependant on the emulator you are using, not the FE.
As for your OS - if you have an old slow PC then use DOS, otherwise use Windows XP.
Then try all the FE's in the software section to see which you like best :)
