Author Topic: Rotation issues with WideScreen Computer Monitor and MAME  (Read 1736 times)
kahlid74
  • Gaming for a better future!
    • GamersAnon
« on: January 02, 2012, 10:30:11 pm »
So I checked the MAME forums and here and didn't find a solution that fixed my issue.  I've got a 16:9 computer CRT monitor with -norotate set on MAME running version .80 (This is the catalog of games I have).
When I run games like 1941 MAME words are upright but the game is clockwise rotated by 90 degrees.  Before I used the -norotate clause the MAME text would be rotated too.
I've tried every parameter I see in the logs but nothing prevents it from rotating.  I've turned DirectDraw and Direct3d off and still no luck.
Can someone please tell me how I can force these games upright with Black Bars on the sides?  It's driving me insane!!
z
  • Last login:September 09, 2022, 01:14:24 pm
  • there will always be one more thing to tweak
    • arcademic hall
Re: Rotation issues with WideScreen Computer Monitor and MAME
« Reply #1 on: January 02, 2012, 11:01:09 pm »
Any chance you have intel onboard graphics on your system?  If so I fought the same battle (need to disable autorotate in the intel graphics driver), here's the background post for you:
http://forum.arcadecontrols.com/index.php?topic=90848.msg954007#msg954007
Hope this helps
Lifetime Student at   Arcademic Hall  (uprights with a minor in cocktails)
kahlid74
    • GamersAnon
« Reply #2 on: January 03, 2012, 09:19:51 am »
Brilliant!  I'm using a GeForce AGP card but the onboard Intel drivers were definitely installed as I was swapping stuff in and out.  When I get home I'll log onto it and do the steps you outlined in that thread and hopefully it will work as expected!!
kahlid74
    • GamersAnon
« Reply #3 on: January 04, 2012, 10:52:27 am »
Okay so here's what I did:
  • Uninstalled Intel Drivers
  • Rebooted
  • Tried again but no success
  • Removed GeForce card from AGP slot
  • Reinstalled Intel drivers
  • Disabled Rotation in Intel drivers menu
  • Rebooted computer
  • Removed the -norotate from MAME.INI
And now it works like a champ!
