Author Topic: I think my monitor is broken  (Read 1258 times)
honkey
  • Last login:December 16, 2015, 02:54:04 pm
« on: December 30, 2011, 07:59:57 pm »
Is there an easy way to tell? It displays dots and red, green, and blue scrambled colors when the computer is booting up and this should be out of the resolution of the monitor. I used to see the screen collapse when I pulled the plug, and I could hear a high pitch whistle when it booted up. None of that happens anymore. I had been trying to get my computer to work with it and I am wondering if I somehow damaged it. It had been working fine when thte Tekken Tag board was in there, but I can not check to see if it still works with the board because I sold it. I had started to think I would just put in a spare 27 inch TV and take out the monitor, but I do not even have a way to do this right now since my video card doesn't have TV out.
honkey
Re: I think my monitor is broken
« Reply #1 on: December 30, 2011, 08:23:20 pm »
Update: I remembered that a few weeks ago when I was trying to figure this out, I saw a spark from the plug that connects the monitor to the power supply. I realized that the previous owner had just pushed the wires into the plastic piece and taped it. I went to check that connection and I blew a fuse, so now the marquee doesn't even light up anymore. Is it possible that the spark I saw last week blew out the monitor? I do not know how this stuff works. Obviously I need to get a new fuse.
Funnel
  • Last login:September 19, 2024, 12:45:19 pm
  • Made ya think, didn't I?
« Reply #2 on: December 30, 2011, 10:14:06 pm »
The only thing I would suggest you to do is post this on the Monitor/Video section... the monitor gurus are obviously there
