Author Topic: Another Polo 25" another problem  (Read 1439 times)
Arm123
  • Last login:March 03, 2025, 11:26:20 am
« on: December 27, 2011, 02:13:09 am »
I have another chassis here that i patched up some bad fractures in the deflection area.
Still wouldnt fire up and the B+ measured +180v
Lifted L103 and the B+ is still +180v, not being regulated by the SMPS.  Replaced c114 and all the other caps in the PSU section look good.
What voltage reading should i be getting from the output of pin 6 on IC101 ?
How should i go about check T101 ?..
