Author Topic: WG25k7000 - Verticaly squeezed in the middle / Streched on top and bottom  (Read 2576 times)
ebo0763
  • Last login:May 23, 2016, 12:37:58 am
I have a WG k7000 25" with new cap kit. The image is squeezed in the middle but stretched on top and bottom. So a circle in the top or bottom will actually take the shape of an egg because of the distortion.
I replaced all capacitors (except the very huge one) and I don't know what could cause that.
Any idea?
BTW, the picture doesn't do it justice because the camera was too close and that kind of cancel out the distortion a bit. But it's still noticable.
ebo0763
Re: WG25k7000 - Verticaly squeezed in the middle / Streched on top and bottom
« Reply #1 on: December 23, 2011, 05:27:01 pm »
I'm just thinking... is it possible that the yoke is a bit too close? It seems to me, if it would be further back it would fix it, at least a bit. But I'm very hesitant to play with the yoke. Hope it's something else.
« Last Edit: December 23, 2011, 05:45:18 pm by ebo0763 »
grantspain
« Reply #2 on: December 23, 2011, 05:58:18 pm »
if the yoke has always been in it's present position then I can't see any reason why that would affect the picture.
questions,is that the original tube/yoke combo for that chassis,did the picture display like that before you replaced the caps
ebo0763
« Reply #3 on: December 23, 2011, 06:06:09 pm »
It's a not the original chassis, but the chassis that was there before was still a k7000. I just received the monitor recently so I don't really know its full story unfortunatly... I don't know if the yoke and tube are the original combination.
And yes, even before I installed the new caps the image was like that.
« Last Edit: December 23, 2011, 06:09:08 pm by ebo0763 »
grantspain
« Reply #4 on: December 23, 2011, 06:08:47 pm »
its a yoke/chassis mismatch imo
ebo0763
« Reply #5 on: December 23, 2011, 06:34:30 pm »
 :-\   Well... is there anyway I could test that?
grantspain
« Reply #6 on: December 23, 2011, 07:32:46 pm »
only if you had an original crt/yoke/chassis to compare with
mgb
  • North East, US
« Reply #7 on: December 24, 2011, 09:35:19 pm »
I would suppose you could at least pull the yoke line and measure the resistance and then compare that with a known good one. I'm sure someone here would be able to tell you what the resistance should be.
ed12
« Reply #8 on: December 24, 2011, 10:40:38 pm »
it is the yoke
wg will confrim it
the part is nla
the yoke will yank out the vert ic in this state
what u want to do is call them and get the vert resistance
find a yoke to match it
is it single/dual freg ?
kv's came both way's
ed
