Author Topic: Rolling Screen w/ JPAC  (Read 2034 times)
mike96sc2
  • Last login:September 14, 2016, 10:33:27 pm
« on: December 18, 2011, 07:35:48 pm »
I installed Soft15 and tried to boot my PC through my JPac. I expected nothing to show up until Windows booted into 15kHz mode and I was okay with that. Instead I had a rolling screen throughout and I could see something in the background that appeared to be related to the boot process.
Did I do something wrong, I just plugged in the JPAC into the VGA and into the Jamma harness. I was just trying to do a soft check to confirm all was right.
I can't find a decent tutorial or directions on installation to help me through this so I'm kinda frustrated. (1) is there any way to resolve this problem and (2) is there a good tutorial for actually going through the process to make this work?
Re: Rolling Screen w/ JPAC
« Reply #1 on: December 18, 2011, 09:02:44 pm »
What's your resolution set at on your computer? 640x480 is a good starting resolution. If it's still scrolling, adjust your vertical hold pot on the monitor.
mike96sc2
« Reply #2 on: December 18, 2011, 10:06:57 pm »
I think it's 800 x 600, I don't even get that far as it just rolls and scrolls from the moment I power up the PC.
I noticed the monitor says it can handle up to 60hz resolution so I don't know if I need to change some settings further instead of running Soft15.
I did play with my vertical hold a bit, but it didn't seem to help much, it rolled around up and down with the slightest turn. I also get the dual picture thing I have heard others mention, where a second image appears ghosted to the lower right of another.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #3 on: December 22, 2011, 06:49:16 am »
Is the J-PAC powered via USB or PS/2 port? Are the LEDs lighting on the J-PAC?
Andy
