Author Topic: Wells Gardner 9200 27" digital (Wiring Question)-(pincusion re-visited)  (Read 2049 times)
chillinwater
  • Last login:February 04, 2026, 10:32:07 pm
Does anyone know the polarity of the W801 deflection board socket
and also the polarity of the P204 video neck board socket?
Are the two sockets even polarity sensitive?
I just replaced the whole thing (deflection board, video neck board and remote control board) because the screen started pincushioning a couple of months back and wasnt able to be adjusted anymore.
I have everything else wired (confidently) but Im scared as hell with these two last connections (damn why didnt I mark them).
Currently there does seem to be a direction to the ease of inserting them into the sockets, one way is easy the other way not so much without forcing them into the sockets.
I just dont want to take the chance before firing it up.
« Last Edit: February 19, 2013, 12:13:25 pm by chillinwater »
  • Last login:February 20, 2026, 07:25:33 pm
Re: Wells Gardner 9200 27" digital (Wiring Question)
« Reply #1 on: December 19, 2011, 12:15:27 am »
no polarity for either one.
one on the deflection board is the AC for the degauss, the neckboard connector is ground... no polarity.
chillinwater
« Reply #2 on: December 19, 2011, 02:56:48 am »
Thanks,  :cheers:
Yeah I didnt think so cuz they didnt have any special grooves or guides on them to prevent reverse polarity but wasnt sure.
So, tried it pushing them in the easy way.
I guess there are more problems though...
-screen stays black
-can hear the normal clicking as if no signal or in screen saver mode (typical when the monitor was working)
-can see the green power lite on the deflection board.
-everything else appears to be seated properly.
(no burning smell!!)
Ive read about 8 times out of 10 that a black screen may be caused by a bad power supply.?.
The board (deflection, neck, remote) are all brand new from WG as a $175.00 replacement, I've had it for about 3 months in bag and box though since I just moved and finally had a chance to install it.
Guess I should call them to see if there is somthing Im missing like a special procedure with a new board, with windows or somthing else or to see if they'll replace it after 3 months..I doubt it.
If nothing else Ill put the old one back in and live with the pin-cushion a little longer.  :cry:
« Reply #3 on: December 19, 2011, 03:03:32 pm »
sometimes they ship replacement boards and replacement flybacks with the "screen" control on the flyback turned all the way down. see if that's it.
chillinwater
« Reply #4 on: December 19, 2011, 07:17:57 pm »
hmmm, I'll have to dig through a schematic and see what\where exactly I'm supposed to do this.
Noob here if you hadnt noticed!  ???
[edit]
is it one of these guys in the attachment?
« Last Edit: December 19, 2011, 07:44:30 pm by chillinwater »
« Reply #5 on: December 20, 2011, 02:48:36 pm »
yes the top one usually is the "Focus" control and the bottom is the "screen" control. sometimes they will have 3, in which case, the top 2 will be focus and the bottom screen.
the screen control basically controls the amount of high voltage is being spit out to the screen. more voltage, brighter picture... sort of
chillinwater
Re: Wells Gardner 9200 27" digital (Wiring Question)-(SOLVED)
« Reply #6 on: December 20, 2011, 08:33:18 pm »
Holy ---steaming pile of meadow muffin---!!!
lilshawn, you just saved my Christmas!!!
After my girlfriend kicked me out and I had the pincushion with the old board and blackscreen with the new...
I was going to have to put my cab in storage and make me a sad panda.
Had to jump through a few hoops
-got the brightness adjusted but just said "no signal" on screen. wtf?
-disconnected my (2) act lab guns to get a direct graphics card to monitor link, still "no signal"
-then went to display properties, dont know what I did, just opened and closed the properties for the wg, clicked "OK" and it fired right up!
Looks better then when I first bought the dang thing!
I'll see about re-attaching the act labs but then again maybe not, I hate the way the screen flashes when you shoot and I know there are more modern gun solutions out there.
I'm thinking a new Christmas present to myself thanks to you!
You saved my Christmas!!! :notworthy: :cheers: :notworthy:
Merry Christmas to you or whatever your pleasure!!
« Last Edit: December 23, 2011, 08:00:23 pm by chillinwater »
chillinwater
Re: Wells Gardner 9200 27" digital (Wiring Question)-(revisted)
« Reply #7 on: February 19, 2013, 12:12:03 pm »
Well this has been awhile but my problem has acted up again, actually shortly after the original fix...
Since its related to the original issue I though id post here again.
replaced-(deflection board, video neck board and remote control board) worked for a bit fixing the original pincusion problem but now I get "pincusion" again.
Everything else is fine.
I called Wells Gardner when it happened long ago and the guy mentioned that somthing may not be grounded.
I will call him again but our schedules dont seem to match.
I trust the gurus here more anyway :D
So where do you think I start to look or test?
In the power strip? (smart strip)
Wall outlet?
Chassis?
Deflection board?
loose wire somwhere?
Back of tube at that rubber cup thingy?
