Author Topic: MDF vs MDO  (Read 1467 times)
GregD
  • Last login:December 19, 2024, 04:27:31 pm
    • Arcade Nebula
MDF vs MDO
« on: December 11, 2011, 04:06:30 pm »
Has anyone built projects out of both MDF and MDO?  I plan on painting my cabinet and was wondering if it will be worth it to spring for the MDO.  thanks
Bender
Re: MDF vs MDO
« Reply #1 on: December 11, 2011, 11:49:34 pm »
if you can afford it, MDO all the way, it's 1/3 to 1/2 lighter, its stronger, you can screw into it safely, and its far more moisture and dent resistant, plus no formaldehyde dust everywhere
and the laminate/paper face takes paint better IMHO
cons: Pricey, hard to find, look closely at the sheets you are buying once in a while you can see the plywood grain through the paper/laminate and you don't want that to show up in the paint, so pick a different sheet
« Last Edit: December 11, 2011, 11:51:11 pm by Bender »
SammyWI
Re: MDF vs MDO
« Reply #2 on: December 12, 2011, 09:00:54 pm »
+1
I've used MDO for the majority of my cab with MDF in the CP box where I need to have some routed edges.  IMO, MDO is well worth the premium everywhere that you don't need a finished edge without T molding.
GregD
    • Arcade Nebula
Re: MDF vs MDO
« Reply #3 on: December 12, 2011, 09:24:36 pm »
Very good.  I am going to use 5/8" MDO to cut down on weight.  Looks like t molding is available in that width.
