Author Topic: Does MAME support Asteroids cocktail mode in any form?  (Read 1958 times)
jimmy2x2x
« on: December 10, 2011, 12:22:22 am »
I assumed it would as the original has a cocktail cabinet, cant seem to find the dipswitch setting for it in any of the versions I have here
BobA
  • What Me Worry?
Re: Does MAME support Asteroids cocktail mode in any form?
« Reply #1 on: December 10, 2011, 12:30:52 am »
Under video settings in the tab menu you can choose cocktail.
jimmy2x2x
« Reply #2 on: December 10, 2011, 12:40:17 am »
True, but that presents a dual screen - this mode is for games that don't natively support cocktail mode isn't it?
BobA
  • What Me Worry?
« Reply #3 on: December 10, 2011, 10:04:37 am »
I know it is just a work around but I get the gut feeling that the emulation is true and maybe there was a hardware (read not dip) change to make the board run in cocktail mode.  In that case there would not be a way to change to the cocktail mode via software in the emulation.  You will probably need someone more familiar with a true asteroids board to find out if this is true.  Just a guess since cocktail mode has been a problem for asteroids in MAME forever.
Here is a tread that seems to confirm that Ground a pin
« Last Edit: December 10, 2011, 10:07:48 am by BobA »
jimmy2x2x
« Reply #4 on: December 10, 2011, 02:20:40 pm »
Thanks for the info Bob
