Author Topic: Arcad monitor Sync problem can't get vertical to stop scrolling  (Read 2035 times)
pyr0matic
  • Last login:November 29, 2011, 12:16:04 am
I'm running:
Windows XP home SP pack 2
Intel celeron 3ghz 1 gig ram
Jaton Video88Pci32mb Nvidia TNT2 Video card Forceware 66.93
Soft15khz, quick res, powerstrip
Jpac- Vga cable
Image looks fine.... but won't sync vertically. Can slow it down with V hold... but cant get it to completely stop.
Arcade monitor in cab.... 20 year old betson. Works fine with jamma PCB
Do i need to combine for composite sync? Perhaps a different videocard?
Re: Arcad monitor Sync problem can't get vertical to stop scrolling
« Reply #1 on: November 28, 2011, 10:10:15 pm »
What resolution is your computer set at? Do you have the quickres utility installed?
pyr0matic
« Reply #2 on: November 28, 2011, 10:25:48 pm »
Quickres is installed and I've tried many many resolutions... no luck
« Reply #3 on: November 29, 2011, 09:05:23 am »
Got a pic of the monitor signal connector?
« Last Edit: November 29, 2011, 09:20:22 am by Nephasth »
