Author Topic: Frankenpanel Controller Mapping's - How is YOURS done??  (Read 1515 times)
planbee
  • Last login:June 08, 2012, 10:25:17 pm
« on: November 27, 2011, 10:57:54 pm »
So I'm nearing the stage of wiring up my control panel, and as it is a DIY version of North Coast Customs quad cp design I thought I'd do a little prep work before I get started.
I'm trying to work out the most suitable way to configure the IPAC 4.
Can everyone out there who have a control panel with an IPAC 4 inside please put up their configuration settings??
Let's start the insanity!  :banghead:
Peja
  • Last login:June 09, 2015, 04:48:22 pm
Re: Frankenpanel Controller Mapping's - How is YOURS done??
« Reply #1 on: November 28, 2011, 10:56:24 am »
As someone who is also probably going to go the NorthCoast DIY quad route, what controls did you decide to go with and roughly what did they cost?
Sorry I don't have any useful information to give you on your mapping, I am newbie and looking at what others are doing.
Thanks and good luck planbee!!
planbee
« Reply #2 on: November 29, 2011, 04:47:01 pm »
Well the majority of the parts came from Groovy Game Gear.... electric ice 2 buttons, electric ice trackball, turbo twist high/low spinner with translucent white base plate for illumination. The joysticks I got from retroarcadeslive.com, though their RGB (multi) colour sticks have changed now, you can no longer control the colours as they have started using auto colour scrolling led's inside. A little mod work and I changed them to what I was after.
As for the prices, it depends on your actual setup. It definitely is not necessary at all to go the added cost of illuminating everything though I spent around $1000 AUD on the control panel parts. I have a total of 53 push buttons on my control panel and I want to light them all up  ???
Hope this helps...
Jason
Peja
« Reply #3 on: November 29, 2011, 05:20:51 pm »
Thanks Jason for the info.  I probably won't want the extra cost of all the lights on my buttons so I will just do normal boring buttons.  I am thinking about doing 4 u360s for each player and then the 7 buttons for 1 and 2 player and then the 4 buttons for 3 and 4 player unless there is a need to go more buttons for the latter.
I will also have a track ball and possibly a spinner.  Did you get their basic pre made kit or did you design it yourself and have them cut it to your specs?
Thanks again for the info!!
Gray_Area
  • -Banned-
  • -Banned-
« Reply #4 on: December 03, 2011, 04:48:58 am »
You mean, you have four sticks with six buttons each, and there are only 26 letters in the alphabet?
-Banned-
