Author Topic: What could cause resistor to test as shorted?(two of the same chassis)  (Read 1463 times)
AE35
  • Last login:January 18, 2022, 01:48:24 pm
  • That sure is a nice raygun!
Hi !
I have two of the same chassis, one works and the other works, but one of the vertical transistors gets very hot.
On these chassis there's a large 160ohm 20W resistors in the PS section, and on the good chassis this
tests fine in circuit, but on the bad chassis it tests as shorted. When I lift a leg, it tests as it should.
So, are there any components that *generally* cause a resistor to test as a short?
It's the big resistor in the top:
BobA
  • What Me Worry?
Re: What could cause resistor to test as shorted?(two of the same chassis)
« Reply #1 on: November 25, 2011, 03:29:46 pm »
If the resistor checks OK with a leg lifted then it is a component in parallel with the resistor that is shorted.  Look at the circuit diagram or post it here.
