Author Topic: Is there a way to easily size snaps/marquees etc?  (Read 3647 times)
« on: November 25, 2011, 10:31:44 am »
Working on my custom layout and one thing that is driving me crazy is that some snaps and marquees aren't taking up the allotted space I have for them in my layout.
Is there an easy way to force this, without having to go in and size every singe snap and marquee identically?
TopJimmyCooks
Re: Is there a way to easily size snaps/marquees etc?
« Reply #1 on: November 25, 2011, 11:07:16 am »
you can batch resize with adobe photoshop or a similar program.  Mala doesn't have any way to resize images on the fly.
« Reply #2 on: November 25, 2011, 11:12:04 am »
Thanks man,  I'll look up some stuff on batch resizing.
Celsius
  • Last login:May 10, 2015, 11:40:41 am
    • Rcade project
« Reply #3 on: November 25, 2011, 11:29:43 am »
there is a stretch option in mala to fit images...but it stretches everything, so if you're using an info window,all marquees/cab/snap images will have the same size...for example if you select a square area for you're info window...a square snap isn't a prob, but marquees :s
« Reply #4 on: November 25, 2011, 11:39:20 am »
I might play with that option Celsius, but somehow I feel like I'm going to end up infront of image editing software for a long, long time, but that's okay I can finally fix all the snaps that Fusion takes to gid rid of the black margins and give all my snaps true transparency.
Now all I have to figure out is how I'm going to get my wife to let me spend the hours its going to take to accomplish all this!
« Reply #5 on: November 26, 2011, 12:43:02 am »
Just an FYI i downloaded this program to batch resize and it worked pretty well..  although in XP I swore there was an option to do this in windows without software... To bad at home I have vista and it sucks.  Nevertheless this worked just fine.
http://download.cnet.com/windows/3055-12511_4-10297789.html?tag=pdl-red
Since every marquee from progettosnaps is already 500 pixels wide for the most part I thought to minimize distortion I would go with 500 x 150.  So far I'm satisfied with the results.  Now if I can just get a layout I'm satisfied with to hold them I'll be in business.
« Last Edit: November 26, 2011, 12:44:56 am by harveybirdman »
