Author Topic: VGA to SCART cable problem with white banding on top of screen. (photos)  (Read 3767 times)
WalkToFreedom
  • Last login:December 13, 2015, 02:33:09 pm
Hi. The screen I am using is from a RCA TV 28DG170A but the tube is actually a Thomson TX807C / CS-N2I.
I'm using this screen in my MAME project. I wired up a cable from the inserted diagram. For the most part it looks great, but if you take a look at the photos there is some white banding at the top of the screen and I have no idea how it is caused, I thought I might have been a grounding issue as if I removed the ground the banding would disappear but brightness would go down and the colours would look dull. I have since stuck the tube into my cabinet with the hope that I will somehow solve the problem. I have tried it on another almost identical TV (same model but 29" flat screen) and I get the same result, so I'm thinking is there some problem with the cable itself? I also have the User manual for the TV which includes circuit diagrams if that helps. Would really love to solve this problem as apart from this everything else in my project is looking brilliant.
Thanks in advance. Matt
« Last Edit: November 17, 2011, 04:11:16 pm by WalkToFreedom »
ArcadeVGA 3000
VGA -> SCART/RGB (dodgy diode circuit creates combined sync)
28" THOMSON CRT
Sanwa 2p 8 way 6 button
Intel i3-4130 Haswell
Asrock H81M
Corsair 8GB DD3
3TB Segate Barracuda (ROMS)
60GB Cosair SSD (OS)
Win7 PRO
Raspberry Pi2
RetroPie
HDMI -> VGA Convertor
fredster
  • Grand Prophet of Arcadeology
  • Last login:February 16, 2019, 04:28:53 pm
  • It's all good!
Re: VGA to SCART cable problem with white banding on top of screen. (photos)
« Reply #1 on: November 17, 2011, 04:19:23 pm »
Did you try and modify your computer video settings? It looks like it works for the most part, but maybe your refresh rate is too low.  Can you tweak that?
King of the Flying Monkeys from the Dark Side
MonMotha
« Reply #2 on: November 17, 2011, 04:39:13 pm »
Some SCART TVs require that the inputs be AC coupled using large coupling capacitors.  220uF bipolar rated 5V or higher is generally sufficient.
WalkToFreedom
« Reply #3 on: November 17, 2011, 04:49:55 pm »
Hi. Thanks for your reply. I don't think the refresh rate is too low as that varies depending on the resolution set, I've tried using Soft15hz and an ArcadeVGA card still the same result.
ArcadeVGA 3000
28" THOMSON CRT
Asrock H81M
Corsair 8GB DD3
Win7 PRO
Raspberry Pi2
RetroPie
WalkToFreedom
« Reply #4 on: November 17, 2011, 04:51:54 pm »
Hi. Thanks for your reply. I have no idea what that means but I'm going to consult with one of my colleagues and get back to you. Thanks!
ArcadeVGA 3000
28" THOMSON CRT
Asrock H81M
Corsair 8GB DD3
Win7 PRO
Raspberry Pi2
RetroPie
WalkToFreedom
« Reply #5 on: November 17, 2011, 05:48:14 pm »
Hi. Still didn't really understand what he said something about is it on a sync signal or RGB signal but he thinks it's a problem with the sync. I also had another suggestion that this might fix the problem: http://members.optusnet.com.au/eviltim/scart.htm
ArcadeVGA 3000
28" THOMSON CRT
Asrock H81M
Corsair 8GB DD3
Win7 PRO
Raspberry Pi2
RetroPie
MonMotha
« Reply #6 on: November 17, 2011, 11:08:25 pm »
You place a capacitor between the PC and the TV on each video (RGB) signal.
WalkToFreedom
« Reply #7 on: November 18, 2011, 10:14:29 pm »
Here is some updated info.
- I tried it with another PC (P4) using an AGP WinFast card using Soft-15khz and it produces the same result.
- The other PC I have is a AMD X2 with an ArcadeVGA PCIe card.
- The AGP version is slightly better (less banding, by maybe 10mm) than the PCIe version.
- I connected a PS1 with an official PS1 SCART cable to the TV and it works absolutely fine, crisp and clear right to the top of the screen.
- Have made another cable and still the same result.
Hopefully this will shed some light on the problem!
« Last Edit: November 18, 2011, 10:16:34 pm by WalkToFreedom »
ArcadeVGA 3000
28" THOMSON CRT
Asrock H81M
Corsair 8GB DD3
Win7 PRO
Raspberry Pi2
RetroPie
WalkToFreedom
« Reply #8 on: November 18, 2011, 10:26:29 pm »
Hi. Thanks for your reply. Could you explain a bit more how this relates to the problem. Thanks!
« Last Edit: November 19, 2011, 04:57:02 pm by WalkToFreedom »
ArcadeVGA 3000
28" THOMSON CRT
Asrock H81M
Corsair 8GB DD3
Win7 PRO
Raspberry Pi2
RetroPie
WalkToFreedom
« Reply #9 on: November 27, 2011, 08:20:22 pm »
Good news citizens! The problem is fixed!
Many thanks to Tim and his super duper 'Dodgy Diode' circuit: http://members.optusnet.com.au/eviltim/scart.htm
Basically the problem was with joining the two sync wires together. I trawled the Internet and came across many diagrams that showed this is the way to do it. However, if you take a look at the link it shows the right way to create a combined sync.
Thanks to everyone for your input!
Now onto the Artwork!
Up, up and away!!!
ArcadeVGA 3000
28" THOMSON CRT
Asrock H81M
Corsair 8GB DD3
Win7 PRO
Raspberry Pi2
RetroPie
Paradroid
    • SCART Hunter
« Reply #10 on: November 27, 2011, 10:10:09 pm »
Great! That must feel good... :)
WalkToFreedom
« Reply #11 on: November 28, 2011, 06:19:49 pm »
Soooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo gooooooooooooooooooooooooooooooooo!!!  :applaud: 8) :afro:
ArcadeVGA 3000
28" THOMSON CRT
Asrock H81M
Corsair 8GB DD3
Win7 PRO
Raspberry Pi2
RetroPie
