Author Topic: Logitech Wireless Controller  (Read 2378 times)
Hildy_42
  • Last login:December 25, 2011, 10:20:06 pm
« on: November 14, 2011, 04:26:19 pm »
Wanted to see if anyone else had the same problem and if I was doing something wrong in the setup.  I am running AtomicFE with JNES for my NES games.  So I purchased a logitech wireless game controller (F710), everything works great with the controller except I have to use one of the mini joysticks instead of the 8-way D-pad.  When I set it up using the 8-way D-pad I am unable to get it to do diagonals.  Has anyone else ran across this problem and if you have how did you fix it?  I would rather use the D-pad so it is more like the original controller than one of the mini joysticks.  Any help is greatly appreciated.
sharpfork
    • KADE
Re: Logitech Wireless Controller
« Reply #1 on: December 05, 2011, 10:51:13 pm »
Have you tried all three input modes?  The manual says it is an 8-way D pad.
read:  Using game interface mode
On this PDF: http://www.logitech.com/assets/34885/f710620-002923003403gswamr.pdf
Hildy_42
« Reply #2 on: December 14, 2011, 02:42:20 pm »
I actually got it to work using a different emulator.  Something in JNES must have been the issue.  Thanks for the link though that actually answered another question I had on it.
