Author Topic: Sanyo 20Ez b+ 122v  (Read 1916 times)
mgb
  • North East, US
Sanyo 20Ez b+ 122v
« on: November 13, 2011, 10:13:47 pm »
Kind of a vague dumb question, but I'm hoping for something obvious that I missed. I recently worked on some machines for a guy. His Mario Bros monitor was squished up top.
First thing I figured was check B+ on the monitor. B+ would not adjust over 90v. So I figured lets give a cap kit. While doing the deluxe cap kit, I also replaced the b+ adjustment pot (5k, from Bob Roberts)
After doing the cap kit, I brought it to check it out on some one elses Donkey Kong because I don't have a 100 volt power source. I didn't hook up the video and all that (Though I should have) But I plugged it in and metered the b+. It was at around 107. I went to give it a small tweak to 108 but it just kept slowly rising to 122v or so and would not adjust down. I really wanted to get this setup before going back to the owners house because its a good length drive. I know I should have plugged it all into the donkey kong for check out, I don't know why I didn't.
Any ideas would be very helpful. I suppose it could be the power filter cap, it just seems weird that it wasn't high before th cap kit.
corycet
  • Last login:June 09, 2012, 01:35:58 am
Re: Sanyo 20Ez b+ 122v
« Reply #1 on: November 13, 2011, 11:54:27 pm »
Forgetting to hook up video shouldn't have caused you any issues. I recommend checking all of your solder joints for solder bridges or poor solder connections on your newly installed cap kit, then hook up your video and try readjusting your B+.
