Author Topic: Will this switch work?  (Read 2285 times)
AussieCade
  • Last login:January 04, 2012, 08:33:22 am
« on: November 11, 2011, 07:05:01 pm »
Hi,
Just wondering if someone can tell me if this switch will work to rewire my pc power. Its a momentary rocker switch.
It has 6 inputs on it. does that matter? If im right the pc switch only has 3?
SavannahLion
Re: Will this switch work?
« Reply #1 on: November 12, 2011, 01:43:49 pm »
Unless you have some proprietary hardware you're using, a standard PC ATX switch is a momentary on switch with a minimum of two leads. They can have more leads, the others are just unused. This is why some builders are able to use arcade buttons to replace their PC switch.
So the answer to your question is yes, you can use that. Just make sure you wire it appropriately. You likely have two pairs (the first and second row) that are grouped together focus only on the top or bottom row. The center should be your common while one is always "on" and the other is always "off". If you have a multimeter, you can easily figure it out. Otherwise, if the PC behaves strangely, swap the connection on the "left" (in the picture) to the connection on the "right".
Everything I said is for the ATX style switch. If you're trying to wire up the MAINS feeding the PSU or wiring up an AT style power supply just stop what you're doing right now and change your plans.
AussieCade
« Reply #2 on: November 12, 2011, 10:40:18 pm »
Im rewiring the pc's power push button so i dont have to open up the cabinet every time i wanna turn the pc on. Is that ok?
Excuse my lack of knowledge im still new to all of this.
SavannahLion
« Reply #3 on: November 12, 2011, 11:12:17 pm »
You should be fine. Standard ATX switches go to the motherboard. You can clip the leads and solder or crimp some extensions from the new switch to the motherboard. You can even add the new switch in parallel so the switch on the case is still functional though I don't see much advantage to this. There are probably a thousand sites that describe this process. My wife is staring over my should since I took over her PC for the time being so I'll have to cut out early. If you have any specific Q's on wiring come back and we'll help you.
yaksplat
    • Random Projects
« Reply #4 on: November 13, 2011, 12:05:16 am »
Here's my example of wiring up a power switch.  5 leads on the switch.
http://yaksplat.wordpress.com/2011/10/27/building-the-power-switch/
AussieCade
« Reply #5 on: November 13, 2011, 12:39:11 am »
Thanks for the help guys.
