Author Topic: Mameroom Plans Question  (Read 1758 times)
austinrfnd
  • Last login:March 28, 2004, 06:13:42 pm
« on: September 16, 2003, 02:07:27 am »
Hi,
  My dad and I purchased theUltimate Arcade II
plans.  I have one question.  It says that 3/4 inch of
t-molding needs to be used.  But the wood is 5/8 inch.
 Is there some sort of mistake? or is it compensating
for something that I have overlooked?
-Austin
SNAAAKE
  • -Banned-
  • Last login:July 21, 2004, 03:44:18 am
  • Banned for abusive postings.
Re:Mameroom Plans Question
« Reply #1 on: September 16, 2003, 02:12:31 am »
Hi,
-Austin
 ::) of course its a mistake.U use 5/8" molding for 5/8" wood.
walls83
  • beer is good
« Reply #2 on: September 16, 2003, 03:23:01 am »
or use 3/4 t-molding with 3/4 wood.. :P
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
« Reply #3 on: September 16, 2003, 04:45:45 am »
Yes it is compensating for something you (and the "experts") have overlooked.
LAMINATE, the laminate is nearly 1/8" and 3/4" t-molding covers it perfectly when using 5/8" thick plywood. If you choose to finish with paint then obviously go with t-molding the same width as your MDF or plywood.
Even with laminate you don't HAVE to go with the wider t-molding but I think it looks far more professional to have the edge of the laminate covered.
If you build a frankenpanel, chances are I don't care for you as a person.
SpAwN
  • Last login:August 09, 2006, 01:41:48 pm
  • Mame Cab done, working on restoring a Wurlitzer
« Reply #4 on: September 16, 2003, 09:10:06 am »
Hi,
-Austin
I had the same question. Scott from mameroom.com told me the 3/4 T-Molding is to compensate for the 5/8 wood + Laminate. It looks real good using this setup.
SS427
  • Last login:October 07, 2017, 12:04:24 am
  • Slow Poke, He pack a gun!
« Reply #5 on: September 16, 2003, 09:27:50 am »
Just remember if your using a laminate or some cover that is about 1/8" thick, adjust the slot cut in the wood to compensate (in other words,,,with a cover, the slot will not be perfectly center in the wood as compared to the rest of the cabinet)
ss
    • GroovyGameGear.com
« Reply #6 on: September 16, 2003, 12:52:59 pm »
Also keep in mind that if you do this, make sure you use the panel as your template when you cut your overlay.  Otherwise, everyplace where they don't match perfectly there will be a bulge,  or a gap for nasty stuff to accumulate.
Also, if you decide to use formica, or some other material (paint?) then you'll want to use narrower moulding. It can be trimmed, but it's hard to make it look good without the proper tool.
hyiu
  • Last login:August 29, 2014, 05:36:15 am
  • too many games... too little time....
    • www
« Reply #7 on: September 16, 2003, 01:59:49 pm »
since you paid for the plans.... I would say ask Mameroom for details.....
sorry... don't mean to sound cold / not helpful...
but I have heard only good stuffs about mameroom's fast and responsive help.....
and since its their plan... I would say they should know best.....
Another Brilliant mind ruined by education....  :p
