Author Topic: Chromalite buttons - does anyone know resistor size needed?  (Read 1482 times)
flashlight
  • Last login:November 16, 2014, 04:14:55 pm
« on: November 05, 2011, 11:54:18 pm »
I ordered a set and didnt realize they didnt come with wiring or resistors included. I dont know the resistor size needed, or current draw.
I havent seen them yet to try 5/7/12 volts to see which brightness level is sufficient, but without knowing current draw i cant do the math myself. Any assistance would be greatly appreciated! im building a 4 player panel one "player" at a time.
BobA
  • What Me Worry?
Re: Chromalite buttons - does anyone know resistor size needed?
« Reply #1 on: November 06, 2011, 12:23:09 am »
Comes with a 12V LED which means it has a resistor in series sized for 12V input.
From GGG:
Power Requirement: Any regulated DC voltage between 5 and 12v.  5vDC may be sufficient for normal installations, with 12vDC being recommended where brighter lighting is desired.
Review
« Last Edit: November 06, 2011, 12:27:06 am by BobA »
flashlight
« Reply #2 on: November 06, 2011, 09:34:44 am »
ah so to connect the lez wiz id connect a 12 volt line to the x5v connector on the led wiz, and then run that as a sharedline to all the chromalite buttons? if i ran it as 5 volts and it has a resistor for 12 it would probably be way too dim. I could always try 7 too.  Thanks for the help!
BobA
  • What Me Worry?
« Reply #3 on: November 06, 2011, 11:13:14 am »
Try it at 5V too.  The review said it was good for normal lighting.  Extra bright with 12V.
