Author Topic: R-91 error code  (Read 2276 times)
mountaindew
  • Last login:March 13, 2015, 03:29:13 pm
R-91 error code
« on: November 04, 2011, 11:28:35 am »
my rowe is giving me an error code 30.What does this code mean and how do I fix it.I have the CD adapter conversion hooked up.It was working fine until I tried to add more songs
Ken Layton
  • Guru
  • Technician
Re: R-91 error code
« Reply #1 on: November 04, 2011, 03:41:17 pm »
Error 30 is "Skipped Index Pulse Error" related to the record magazine's optical switch. This means the computer was unable to tell the position of the record magazine because the magazine index pulse was not detected from the optical switches.
Causes could be dirty magazine gear (the optical switches need a clean gear to read the index position), a bad optical switch assembly, the optical switch connector may be dirty/unplugged at the mech control board, or you may need to adjust the mech control board index "I" trimpot .
mountaindew
Re: R-91 error code
« Reply #2 on: November 04, 2011, 04:14:19 pm »
I no longer have the record magazine in there.I now have a 200 disc CD changer with the adapter
Ken Layton
  • Guru
  • Technician
Re: R-91 error code
« Reply #3 on: November 05, 2011, 01:07:14 pm »
Contact the manufacturer of your conversion kit and tell them what's happening.
mountaindew
Re: R-91 error code
« Reply #4 on: November 06, 2011, 03:25:05 pm »
Thanks.I did that and Im in the process of resetting the whole thing
