Author Topic: Having trouble compiling MAME .137  (Read 2136 times)
  • Last login:Yesterday at 08:08:49 am
« on: November 01, 2011, 08:49:13 pm »
I'm trying to compile .137 with some gear shift fixes made directly to the drivers (not applying any diffs).
I decided to stick with the version currently on my driving cab because I'm afraid of California Speed and SF Rush running slower.
It took a lot of tweaking to get them running at a reasonable speed.
Just as an experiment, I'd done this with v.142 using Headkaze's MAME Compiler 64 and everything worked fine.  Only changed a couple drivers on that run though.
The version of MAME Compiler 64 that corresponds with v.137 doesn't seem to be available, so I tried version 1.17 and it didn't work (should it?)
Next, I tried to compile it via command line using the tools that mamedev provides.
(Using an older version of the tools that corresponds to v.137)
The first time I ran it, it appeared to work except for errors in one of the drivers I had messed with.
It appeared not to create the mame.exe
So I redid my changes to that driver and tried again.
(I don't know how to code, I'm copying and pasting from a diff file meant for an older version of MAME, but it worked on v.142)
Now it doesn't get very far before I get the following errors:
Anyone know what's going on without going to too much trouble?
I've deleted everything in the folder, re-extracted MingGW into it and still get the same error.
I've also tried compiling unmodified v.137 and still get the same error.
EDIT: I KEPT SCREWING UP SETTING THE PATH
« Last Edit: November 01, 2011, 09:50:44 pm by BadMouth »
Re: Having trouble compiling MAME .137
« Reply #1 on: November 01, 2011, 09:52:21 pm »
It ran for a long time and looked like everything was working right, but then it stopped here:
I'm heading to bed for the night.  If anyone can tell me what I'm doing wrong without going to too much trouble, I'd appreciate it.
Thanks.
EightBySix
« Reply #2 on: November 03, 2011, 04:31:13 am »
Thanks.
Hard to say for sure. Not cleaning your teeth maybe? Wrong kind of pillow?
« Reply #3 on: November 03, 2011, 09:52:17 am »
Thanks.
That did it.  Working fine now.
(actually, I used Mr. Do's batch files and it worked fine http://mameworld.info/mrdo/compile.html )
headkaze
  • 0x2b|~0x2b?
« Reply #4 on: November 03, 2011, 03:04:30 pm »
When you get an error just try continuing the compile as sometimes it will still complete. This is probably what happened when you used those batch files; it probably just finished off the compile.
