Author Topic: xbox1 no dvd drive, is it posible?  (Read 3607 times)
abispac
  • Last login:December 04, 2025, 01:12:34 am
« on: October 31, 2011, 12:40:36 pm »
Hello, i have an old xbox 1 that i would like to turn into a dedicated bartop arcade or full cab,i got the xbox to jamma dongle, it works just fine. Im trying to add a second hard drive to the xbox, i recalled some one had remove the dvd drive and added a second hard drive , but when i do this i get the error 12 screen , cant seem to find that topic to see how the guy did it. Can anyone help? thanks alot.
Jammin0
Re: xbox1 no dvd drive, is it posible?
« Reply #1 on: October 31, 2011, 12:56:52 pm »
The typical way to do this is to remove the 8-10gig original drive and replace it.  I wouldn't worry about keeping the original drive around because you don't need it.  Even if you are able to get it to run 2 different drives, it won't be any less work then replacing the stock drive.
I don't think there is a way to remove the drive.  If anyone has done it and documented it, you can find it on the forums section of xbox-scene.com.
abispac
« Reply #2 on: October 31, 2011, 01:35:24 pm »
i know theres one way, i just dont find the topic, once i find the solution ill let you know.
Jammin0
« Reply #3 on: October 31, 2011, 02:49:49 pm »
here's the information that I could find on the topic.  I don't notice anyone removing the DVD drive but it looks like you can add more HDDs.
http://xbox-scene.com/xbox-tutorials.php?p=191|211|#211
« Reply #4 on: October 31, 2011, 03:20:30 pm »
Looks like a bios flash: http://forums.xbox-scene.com/index.php?showtopic=306241
Edit: And maybe a mod chip?
« Last Edit: October 31, 2011, 03:22:31 pm by Nephasth »
Jammin0
« Reply #5 on: October 31, 2011, 04:15:05 pm »
Nice find, I was wrong.
abispac
« Reply #6 on: October 31, 2011, 06:07:37 pm »
a ---steaming pile of meadow muffin---, mine its just softmoded so i wont be able to do that, the only option i got its to disaswmble the dvd drive and take the board only. thanks for all the help.
