Author Topic: HELP! Disabled progressive signals in service menu - KV-32HS420  (Read 2516 times)
rCadeGaming
  • Just call me Rob!
« on: October 31, 2011, 12:10:39 pm »
Yesterday I picked up a Sony KV-32HS420 that I found on Craigslist.  It was looking really good with a variety of sources.  PS3 over component worked in 480i, 480p, 720p, and 1080i.  Dreamcast also worked in 480p using VGA through a VGA to component transcoder.
No problems until I tried to get lower resolutions.  I tried Street Fighter Alpha 3 on the Dreamcast (384 x 224 progressive).  On my KV-27FS120 this looks great, it displays in native resolution and you can see some healthy-sized scan lines.  On the 32, there were no scan lines and everything was too sharp.  I could tell that the TV was upscaling to 480p, which is not going to be the best as I was hoping to MAME running some native resolutions on this thing.  I tried using composite right out of the Dreamcast to make sure the VGA Box wasn't doing the upscaling, but got the same result.  Apparently the TV has something called "Digital Reality Creation" which upscales low resolutions to 480.  You set it to upscale to 480i, 480p, or "Cinemotion," whatever that is, but you can't turn the upscaling OFF.  I later realized that it might have to upscale, because the 1080i-capable tube might not accept 15kHz resolutions... but read on.
Frustrated with this, I found the service manual online, got into the service menu and started looking for a way to turn off the upscaling.  After successfully adjusting the geometry and a couple of other things on my 27, I was confident I could find my way around the service menu on this one.  BIG MISTAKE.  None of the adjustments are labeled properly in the service manual as to what they do, just 4 letter designations like AFCM and VDJP.  Anyhow after guessing around and being unsuccessful at disabling the upscaling, I thought I should reset everything to the default, in case I changed something I shouldn't have.  As the manual says, I pressed "7 > jump > enter" and "7 > 9 > enter" to reset the "MID NVM Data" and the "SYSTEM NVM Data."  Apparently I should not have done this.  Now the TV won't display anything but a 480i signal or lower.  480p doesn't work, 720p doesn't work, 1080i doesn't work.
Does anyone know how to fix this?  I'm guessing I have to fix something in the service menu, but there's hundreds of adjustments and they're not well labelled.  Please let me know if anyone can help.  I can send you a PDF of the service manual.  If you're looking for it, it's Sony Chassis DA-4, once again the TV is a KV-32HS420.  Thanks.
Jack Burton
Re: HELP! Disabled progressive signals in service menu - KV-32HS420
« Reply #1 on: November 01, 2011, 11:19:19 am »
Your best bet is to cross post this question to the AVS forums.  They are the experts in matters like this.  You can access it here:
http://www.avsforum.com/avs-vb/forumdisplay.php?f=64
The XBR960 thread will be your biggest source of information.  The service menu for it and the HS420 should be nearly identical.
