Author Topic: Powering cab question  (Read 2388 times)
AlienInferno
« on: October 24, 2011, 10:42:02 pm »
How are most people handling the power for their cab.  I know about the smart strip thing but are most people just running the plug out the back of their cab?  I was thinking about using one of those power sockets like what's on pc power supplies (I know some homemade pin cabs are using these).  Mainly so I could unplug it and not have to worry about a cord laying around.  Any thoughts on those?  Does anyone have a link I could find them at?
Thanks,
Justin
AlienInferno
Re: Powering cab question
« Reply #2 on: October 24, 2011, 11:14:13 pm »
Thanks for the link.  I had no idea what those where called.  I tried several Google searchs and ended up with nothing.
Unstupid
« Reply #3 on: October 24, 2011, 11:23:26 pm »
Look for IEC320 and C14 socket....
I use these:  http://www.amazon.com/IEC320-Inlet-Module-Switch-Socket/dp/B0050HH70E/ref=sr_1_5?ie=UTF8&qid=1319512878&sr=8-5
Doesn't come with fuse... you can get em for $.99 anywhere...
AlienInferno
« Reply #4 on: October 25, 2011, 12:01:02 am »
Ok.  So if I'm just planning on wireing the smart strips power cord to the socket and use the pc power switch to turn everything on.  Do I need the switched and/or fused socket or would I be ok with just a socket.
AlienInferno
« Reply #5 on: October 26, 2011, 01:36:08 am »
Just giving it a bump.  Want to know if anyone can answer my last question.  Would like to do this as safely as possible.
TopJimmyCooks
« Reply #6 on: October 26, 2011, 08:59:41 am »
Warning:  I may not be qualified to answer this question.  However, I have an IE320 socket with no fuse, between my smart strip and wall power.  As I see it, it's no different electrically than plugging my smart strip directly into the walls, it's basically a nice extension cord.  And, I would have no problem plugging a pc, monitor into the smart strip then straight to the wall without an added fuse.
That being said, a lot of premade ie320 ports with switches do have fuse holders, so I'm sure there are some applications where fuses are desirable.
AlienInferno
« Reply #7 on: October 26, 2011, 02:18:44 pm »
That's the same thing I was thinking.
Mrephunk
  • Last login:July 17, 2012, 12:56:47 am
« Reply #8 on: October 28, 2011, 01:10:18 pm »
I bought this IEC320 outlet
but want to know how to wire it with the switch, I am pretty sure I know how to do it but would like someone to really tell me how so I don't go frying anything because I wired it wrong ;D
Unstupid
« Reply #9 on: October 28, 2011, 01:18:19 pm »
Mrephunk
« Reply #10 on: October 28, 2011, 03:05:26 pm »
 :notworthy: :notworthy: awesome thanks, that was kinda what I thought
yaksplat
    • Random Projects
« Reply #11 on: October 29, 2011, 10:41:42 am »
I've got a few posts on my blog about this.
http://yaksplat.WordPress.com
I go through handling powering everything on from a single button.
jim
http://yaksplat.wordpress.com
