Author Topic: pga golf vr-gobal  (Read 234829 times)
stpcore
  • Last login:February 09, 2019, 05:48:56 pm
Re: pga golf vr-gobal
« Reply #440 on: September 24, 2012, 10:25:03 am »
Stupid question...I just downloaded and installed mIRC and wanted to know when you (Ed) gets everything online the "channel" we are using will be called "PGA" or will it be ">PGA<" as I'm not certain if that makes a difference.  New to mIRC, never used it before and I know how sensitive computer programs can be!
Offering commercial grade vinyl decal printing for cabinet side art, control panel overlays, monitor bezels, marquees, etc.
stpcore
« Reply #441 on: September 28, 2012, 10:55:02 pm »
It's been a quiet week in here.  Anyone hear of any status updates?
ed12
« Reply #442 on: September 29, 2012, 01:28:48 pm »
hi
no i really have not posted anything this week
the reason is simple,let me try to explain
on my pga's there is 3 different coin accepter's
cash-flow-330/sr5'and a goffie 1,
of that the cash-flow >by far bar none< the best,is a 3 channel output job
where the other's are single output..sound's simple enough right ??
convert to the single output job right ?.problem is u need to rewire...
thus time/money..etc.etc.  and in the feild this will not work or bold well,or find a fix
welp i i found a fix..so i am testing the fix...
thus why no updtate's
now onto the server...my pga is called ed's_personal_pga << rem that...
channel is called pga
to ping bot it is !files
to obtain file's it is !the name of the file u want
to serv into !ed's_personal_pga u must MUST type that exact line
and u go real time,please try not to tie up my b/w to much :):)
this is all done through the private channel
now rem rule's
a=aboustley no dialup
b=hook to the lan port of your putter .. d/l the driver called >>>lan.pga.ini<<<,it will auto setup your lan,sit back relax..it take's a byte to load
c=t10 or t100 is fine >u are comming into a tierabyte router
d=u can cuss between each other,as i do not monitior that
e=u CANNOT pass porn PERIOD it will not be ALLOWED AND U WILL BE ADDY BANNED
i think these are fair and simple enough to understand
ed
Spitfire
  • Last login:August 05, 2023, 07:55:31 am
« Reply #443 on: September 29, 2012, 11:45:24 pm »
Hi Ed, should we be downloading these files from the PGA machine pc or is it ok to download to another pc such as laptop and then copy the files over to the PGA pc later?
Thx Joe
CVN53
  • Last login:December 24, 2013, 10:33:27 am
« Reply #444 on: September 30, 2012, 11:40:31 am »
Hi Ed
  First off Thank you for all your work.I am confused I have a machine thai is owned by a customer who wants his tower back and is getting very inpatient with me on not getting it done,so bottom line is I am confused on what the server is for, playing on lan or getting files.Are you creating new iso disc of the game so every thing is unlocked so we can change video cards,play with no dongle,unlock courses and players.It seems you change direction so much I am not sure whats going on.
CVN53
stpcore
« Reply #445 on: September 30, 2012, 12:20:41 pm »
I am also confused as to what is happening at this point.   I know once I get a better understanding this will all start making sense to me.  Thanks for everything Ed!
ed12
« Reply #446 on: September 30, 2012, 01:58:45 pm »
hi
i do not understand the problem here
how is it confusing ?
i set out server rule's
set out bot rule's
cvn53 i shipped the plug u wanted
u on the other hand do not require it to do the work on the pga,as it olny is used for control input stuff >roller-ball/left-hook/right-hook/coin-in/fly-over/etc,<
these can be done by shuting the nessary control line to ground
hence testing,for normal play it would be handy...but as i do run test's
i have done just that >shunted to ground<
now if u are getting donggle error's,player card error's,that a full new set of thing's
as i pointed out to dirt u can just run a new.ini file
ie >control< which in fact tell's the game it dose not need the player's card to run
and or the donggle to open up
i cannot make that any clearer,as i have been explaining the file's are to big to up-load here,hence the reason for a mirc,+the fact u can play real time...neat little ad on
eh ?,the main reason for irc is this thread is getting to cloudly to beable to follow
god know's i have a hard enough time following it,cvn53 if u need the pinout's
ask
ed
stpcore
« Reply #447 on: September 30, 2012, 02:01:52 pm »
I've never used mirc.  I created an account there so what do I do next?  That's the issue I am having.
ed12
« Reply #448 on: September 30, 2012, 03:12:55 pm »
hi
it is is it's own server
ie  if u hook up..u get a list,or u can creat a list of your own,so if u do not want to go
to let's say irc\fxchat.net << server u clear it out of the list
and add in >>gobalpga.net or .org where ever it land's,i will post open channel the addy,just REM it is PRIVATE AND PASSWORD PORTECED....these are the real thing's u need to know,if i find nessary i will KEY IT,which means u will need to know the server/channel/password/key to enter
from there u, as i explained very clearly are in ,
 to obtain file's u first :ping the bot: >>!<< so >>!list<< then u type >>!filename<<
this will give u the files's u tpyed in,so let's say >>!resuce disk 4.1<that is exactley what u will get..they are served real time
TO play on line real time
again !ed's_personal_pga places right into my personal pga,all u are doing is
is TELLING the file server >bot< where u a going,as i do not have a crystal ball..
the bot olny oversee's for me >>server<<,u are routed to the nessary stuff
now all of this is done through the bottom bar..u c it in mirc as a small bar across the bottom of the main window >like windows< in ie6.,it is blank to all other user's expect
pga bot >me<
in the irc option's..setup i allow cussing
but no porn that is set to option explict on..:flase: and the rule is hoof-kick-ban-addy-ban,
u can chat the bot
by typing !pga_chat,again it will give u a list of q's and answer's
so let's say u have a donggle problem..u would type
in the open channel..!pga_chat_donggle..from there u will get a list
of answer's to the most common problem,if u cannot find the answer then ask real time,i will c it and respond..
TO the time limt on irc it is olny a nag
if u do not feel the that u donot want to spend $20.00 then by all mean's do not
i did because i love mirc,it by far is 1 of the best file server's i ever came across
if u have then fine so be it,i care less
TO be very clear this thread was started by me
to find help swapping video card's in the pga's,i had no idea it would go this far
but is but and growing pain's are just that,ever had a baby.?.. i just think i am
TO date i have fully recoded gobal_pga >reged trademark <
there is alot of thing's u no longer need to test and or run your unit
u can swap all u want now
I do not think of any rule with them that u really need to follow anymore??
as i have coded around 99% of the common stuff i have come across
WHAT u need to do is ask the !bot,if the answer is not there
then :ask in pga:, i will get back to u
ed
CVN53
« Reply #449 on: September 30, 2012, 08:09:58 pm »
Hi Ed
Ok I to have never used irc but we need info to connect to your server correct?Yes I would like to have the  pin configuration for the plug in.
Thanks CVN53
ed12
« Reply #450 on: September 30, 2012, 10:00:59 pm »
hi
cvn53
will do  shortley
very shortley
ed
Spitfire
« Reply #451 on: October 01, 2012, 08:11:57 am »
Hi Ed, very clear from oz mate. Haven't as yet connected but will do soon to get my machine running perfect and then ready to play u online mate. See you all soon. Thx heaps Spitfire
stpcore
« Reply #452 on: October 01, 2012, 09:36:56 am »
I don't want to turn this into an mirc tutorial thread but when I launch mirc and do this
1- select "FILE"
2- select "SELECT SERVER"
3- select "ADD"
4- in the "Description" field I enter "PGA"
5- in the "Server" field I entered "gobalpga.net" &  "gobalpga.org" and received a message on both attempts stating "unable to resolve server" (I figured this was a spelling error in your post so I then attempted "globalpga.net" & "globalpga.org" (the letter "L" was missing in the first two) and received the same message on both attempts "unable to resolve server".  I then entered "ed's_personal_pga" in the server field as I saw that mentioned in an earlier post and received the same "unable to resolve server" message.
I notice there is a couple fields that are blank such as "password".  I notice that you said that the server is password protected but I don't remember getting a password.  I'm thinking I'm just being an idiot and missing something or not fully understanding how I'm supposed to connect to the server and I'm posting this here in the event someone else is in my shoes and another member can help us out.  I don't want to throw this thread off topic so if this is not the place for this post I do apologize.
I can't wait to get these files...I just can't quite get there!   :banghead:
ed12
« Reply #453 on: October 01, 2012, 12:46:53 pm »
hi
stpcore u are not
but please wait and i will post the exact inst. as to the how and where
cvn53
your first 19
pga i/o pinout
1=black trackball ground
2=yellow trackball
3=black trackball
4=blue trackball
5=black common ground
6=blank
7=red=? my thought is coin door or coin meter a tad out see pin 16
8=red  shot type
9=yellow fly over
10=orange swing right
11=blue bill vail-valaditor >dba<
12=blank
13=blank
14=blank
15=blank
16=red again i am a tad out on it look's like +5
17=red service switch-will turn to white 17 and 18 must not go to common ground
18=black service switch return
19=blank
will post the rest ltr today
this should get u started
what u really need is the start button to get around any nag
ed
CVN53
« Reply #454 on: October 01, 2012, 03:58:34 pm »
Hi Ed
Thanks  will be awaiting rest of pin layout and server info.
CVN53
ed12
« Reply #455 on: October 01, 2012, 10:23:27 pm »
hi
if SAINT  ever read's these
i am trying to bring pga_bot on line here
what give's SAINT ?
all i want to do is reg it in
ed
pga
  • Newbie
  • Last login:October 04, 2012, 12:00:15 pm
« Reply #456 on: October 03, 2012, 11:59:13 pm »
hi
he did it
i am going real time
mirc is picked/set,few day's now
pga
ed12
« Reply #457 on: October 04, 2012, 12:01:42 am »
hi
welcome aboard pga
ed
stpcore
« Reply #458 on: October 04, 2012, 11:41:18 am »
What's the difference if PGA bot is online here or not (what does that mean)?  We are still using mIRC...no?
We need some sort of official countdown for this launch  ;)
ed12
« Reply #459 on: October 04, 2012, 12:30:26 pm »
hi
pga is the bot
when i glued it in last night it is a prelued to the irc
i would love to give u a official time
but between my shop work-load,and the simple fact i am going to be the mirc host
i wanted to make sure all the t's are crossed and the i's dotted
we will attmemt to glue in the host tonight
ed
Spitfire
« Reply #460 on: October 07, 2012, 06:31:47 am »
Hi all I've been on holidays n just got back. Seems like I have missed heaps need to find some time to get back ip to speed n get my team challenge machine ready for our tournaments. Start work tomorrow though urghh. Anything I need to know Ed or that I have missed to get back up to speed?
Thx Spitfire
ed12
« Reply #461 on: October 08, 2012, 02:12:28 am »
hi
everyone settle your jean's down
this has been a long haul for me
WE ARE GOING INTO >CSNET<,i will post
the EXACT INFO very shortley
let me finish up >ed's_personal_golf_link<,
REM THAT.. OR U CANNOT PLAY THE ADVANCED GAME'S,that i did load into >PGA_BOT<
!!your personal bot!!...the channel is very private
10+..
it is linked to mirc,but is not a mirc,it is weird...but i have the okie dokkie's i need
RULE'S
NO FAKE E-MAIL'S
NO DOUBLE NICK'S >ON THE SAME E-ME ADDY<
this lock's the smart asses out,and YOU WILL GET A HOOF!!!!!!
AND BY HOOF I DO NOT MEAN PGA BUT SERVER BAN
THIS WAS JUST EXPLAINED TO ME....
there filter is set to such..that if u spam
bam u are gone
yes u can cuss in the >PRIVATE CHANNEL<
NO U CANNOT TRANSFER PORN
get ready to enjoy
ed
ed12
« Reply #462 on: October 08, 2012, 02:22:24 am »
hi
i will add it is a undernet.org
need to wait for the exact info
they are chking me now
which is fine with me
it is a mirc link
but it sit's under the >undernet.org< heading
ed
stpcore
« Reply #463 on: October 08, 2012, 05:21:44 pm »
OK, so this will not come to a surprise to anyone I'm sure but I have no idea what this updated info means.  So no mIRC at this point?  I don't think I'm going to follow this for a while because every time I try to play catch up it seems that something else changes.  I appreciate the work, Ed, I really really do.  I will check back with this thread in the future when you guys have everything rolling.  Can't wait to golf with you all!
« Last Edit: October 08, 2012, 05:27:43 pm by stpcore »
ed12
« Reply #464 on: October 09, 2012, 12:52:53 am »
hi
anyone can bail anytime they want
to remove irc
go to system and find mircwin32.ini
here is where i am landing
To continue the registration process go to https://cservice.undernet.org/live/confirm.php?cookie=f00aae47080402148a6d1ebf7963b10c
please note the service
if anyone want's to take on the task
by all means have at it
my personal pga >chip card< came in form roger's
so i need to stick it in also
that is a !!different ip also!!
so u will if u want to go on-line real time stick in that isp also
in short pga_bot carry's all the large file's u need
this is the mirc
the stick allow's for real time traffic
i will not baby sit u through it
it is in the readm-me's
if u can do better,again have at it
it comes normal 2gig b/w..ie 2 way traffic
so i am trying to raise it to 5gig
this will be the test phase of it..ie on-line real time for my aussie ppl
dirt your box did not show up yet ?
cvn53 the other line's u need i will add ltr today
as it is 1:am my time,but i did not forget
u olny need 2 more,as the dba uses the same single line from the coin accepter
read that line please
and the card desipessener we do not use at all
but if u want i will pin them for u ?
the coin accepter is a blue line
the other's i will pin
if your box is working right
it will stall on card reader,and ask u to hit start,once u have done that it should go to course's screen <display>,the start switch is your !!key!!
even if u do not hit that  button
the thing after about 30 sec's should go to game mode
all default's of course
service is a simple wire to ground it is a >white wire<
it will put u into the service mode
u will see the screen >loading< please wait
from there,track-ball and >start< are your buddy's
to turn thing's on and off,u need to edit hercules
ie turn cmd's on or off in real time
before the program can even load
u would do this to add thing's:.dll's/.ocx's:-remove a call/add a call,
now please rember this..as i am tired of repeating it
U CANNOT DO IT WITH THE GAME RUNNING..U MUST DO IT,WITH IT AS A SLAVE
AND USING A EDITOR....notepad should do it fine
remove the OFFENDER CMD..save as the new .ini/.what-ever it is..the extensison
ie .ini/.cmd/.bat what ever..u are olny pointing hercule's to where u want it to find it's driver's,and what to look at and where not to look
in short all u are doing is driving the car..simple
as i explained last night
there must be a total of 10 nick's
no double's for me to get this trick to happen
my bot DOSE NOT COUNT
so i am 1
so 9 more
i think that is clear enough
yes it is mirc linked
ed
stpcore
« Reply #465 on: October 09, 2012, 06:11:27 pm »
I sent you a PM with my requested nickname a couple weeks ago and you responded and said that it was confirmed.  Do I need to resend this to you again?  Thanks.
ed12
« Reply #466 on: October 09, 2012, 11:21:15 pm »
hi
stpcore
no u do not
i have it in the bot
today i recieved my password for the server
so i will invoke all in short order
now rem i said recieved..this mean's i passed the step's
and it was a climb
next step to get to know the admin's
this is the edititcet,u must follow when u want a private server with full bandwith
ie no irc cop can kick u,no irc cop will even look in >they are not allowed<
it is on it's own..not your regular mirc,but linked
did for a few simple reason's
1=we will play real time
2=file size
3=the fact we will be decussing gobalvr,it's gaming and a few other's
which will happen real time
if u know mirc rule's u will see i just walked aroud alot of them
thus the wait..sorry if that pissed anyone of..but i am 1 guy with my hand's full
dirt if u hook in i recieved it today
i know u are busy,will punch it through tommrow
as it is 11:20pm here
ed
dirt
  • Last login:October 30, 2024, 08:36:38 pm
« Reply #467 on: October 09, 2012, 11:35:41 pm »
I'm here ed. Glad it got there. Thanks again!!!!
Sent from my LG-P509 using Tapatalk 2
WANTED: NINTENDO CABINETS WORKING OR NOT
ed12
« Reply #468 on: October 10, 2012, 12:50:09 am »
hi
u never shipped the hard-drive??
u need a new 1 ??
if so just send in a e-me
or pm
it's a no brainer,the cap's on the mobo look fine
good new's there,the i/o card is gen 1 ?
mine are gen 2..hence the s/w mix up
your >key< is usa mine is canada,i will code around it...
:there is a patch i wrote for  gen 1-2: >approved by gobal-vr @reded trade mark<
or if u want i will ship it back full open and u do not need the key ?
this is your call
it is on deck now
u did not put a fan on the video card as per 1 of my post's ????
i will be digging into it more
ed
  • Last login:November 26, 2025, 03:26:23 pm
« Reply #469 on: October 10, 2012, 01:55:05 am »
yes, you need to pretty much put as many fans as you can on this rig, the damn things will overheat like that *snaps fingers*
keep an eye on them too, if they seize up...it's as good as gone.
ed12
« Reply #470 on: October 10, 2012, 06:45:12 am »
hi
dirt
yup u need a fan
yup the card reader is usb >2< not 1,which is the 2 usb's on the back of the board
i will shove in a usb 2 card
second u never sent me the harddrive,so i locked in a spare :caniadain-with-key-1<
guess what i am looking at gobalvr team challange
a=your mobo is fine
b=u need a fan on the video card
c=u need the usb card >2<
d=if u want i will turn hercules down so it will not look for the :key:
e=when i recieved it they bent the bottom of the cab..no biggie..but u need to know this
so in short it is now running
i will tweak the bios
but u need to either tell me to go ahaed with a bypass on herc,or send me it's hd..or tell me to reload usa-s/w ?
ed
« Reply #471 on: October 10, 2012, 10:18:29 am »
meaning USB 2.0
the ports built into computer itself are only usb 1.0
Spitfire
« Reply #472 on: October 10, 2012, 06:18:39 pm »
Hi All,
Sounding very exciting cant wait for it to be all up an running Ed great work mate. I think my graphics card might might be dieing aswell. It has seized up a few times. Have bought new nVidia AGP card but game doesn't like.  Need to get that work around Ed of you so I can install and game will except. Please advise?
Thx Spitfire
dirt
Re: Re: pga golf vr-gobal
« Reply #473 on: October 10, 2012, 07:04:48 pm »
hi
dirt
yup u need a fan
a=your mobo is fine
ed
hi ed,
 I thought you told me not to send the HD. Sorry I misunderstood. I can send it to you but if you can just reload to another HD that would be quicker. Canadian or USA version, I don't care as long as it works in my machine. I trust your judgment. Whatever you need to do to it to get it working and upgraded to all access is fine with me. And again, thank you so much for all your help.
ed12
« Reply #474 on: October 10, 2012, 07:34:52 pm »
hi
first and foremost
all nick's requsted willl be fully respected
as i explained i just recieved my main password for pga
so i am building the channel
second
dirt all is fine
give me byte to tune herc in
and u will be good to go >with or without the key<
the big diff is our key dose not allow for turrnie play,but i walked around it
our key meaning canadian
i will straighten the cab out
leave in the new drive put in a fan
and usb2 card
then ship
about a week or less
but to let u know it has passed a 24hr  test run
so i am happy to start to button it up
oh btw your i/o card is first gen
if u ever need to know
ed
Spitfire
« Reply #475 on: October 15, 2012, 06:39:22 am »
Hi Ed,
Just wondering how things are going with the tournament play as we are ready to go down under mate n awaiting ur instructions.?
Spitfire
stpcore
« Reply #476 on: October 22, 2012, 03:30:13 pm »
Hello Ed.
Hope all is going well with you.  I thought I would check in to see if you have made any additional progress regarding PGA?
Had to replace a power supply on my cab today.  Upgraded to 520 watts and it's running like a champ.  It was a mess getting to the power adapter.  So many wires that were tied off and I couldn't get to some of the connections without some removal of internal parts.  It felt like having to remove the engine of a car to replace the battery.  I'm happy it's done and looking forward to doing some software modifications now.
ed12
« Reply #477 on: October 22, 2012, 11:36:31 pm »
hi
ya guy's all is fine
it has just been a very very busy few week's
u have seen me post in a few thread's
i am by no means inqouring this 1
congrad's on the p/s update
to be exact i had a digital juke box rattle my head
4 time's,i had to contact a nick here to help me out
which worked out really really well
so i have not done anymore work on pga or pga's expect for dirt's which is alive and well,shipping back shortley >with my s/w<,i will do x.net this week then we should be set to go...
please be patinet
ed
ed12
« Reply #478 on: October 25, 2012, 11:46:16 pm »
hi
here is the update u have been looking for
roger's :my-provider: and i have come to term's
i need to pay them $750.00 up-front cash so we can have static
x.net want's 10 signed nick's or i cannot gain control of the server channel i requsted
the roger's account is set..the money is on the way,it just been 1-800-eat----steaming pile of meadow muffin----and-die-line-call's,so please be patient,i am moving as fast as i can,also u will find in pga
bot >v-rock-bot< he's mine for my on music service..touch tune's need's a kick in the nad's,unless u are reged with ME as a vrock owner u will be showded a fast door out
i am working on getting 02-08 gt's back on line,i think i have found the hardware ppl
will post u on that as it envole's
ed
Spitfire
« Reply #479 on: October 28, 2012, 03:47:02 am »
More curves than the great ocean road mate. I hope it all gets sorted out sooner than later mate as very keen to play some goo competition golf. Let me know if we can help in any way. Thx Spitfire
