Author Topic: pga golf vr-gobal  (Read 255668 times)
0 Members and 20 Guests are viewing this topic.
dirt
  • Last login:October 30, 2024, 08:36:38 pm
Re: pga golf vr-gobal
« Reply #200 on: August 05, 2012, 04:37:11 pm »
OK ed I got the new battery and set everything to what you posted. Everything is the same except the ide primary master. Mine says wdc wd1600aajb-oowra
Sent from my LG-P509 using Tapatalk 2
« Last Edit: August 05, 2012, 04:47:42 pm by dirt »
WANTED: NINTENDO CABINETS WORKING OR NOT
ed12
« Reply #201 on: August 05, 2012, 09:09:16 pm »
hi
ok thats your hard drive..size is of no real dif here
now what did it do when u fired it up
did it load up ? load error out ? or just sit there ?
ed
dirt
« Reply #202 on: August 05, 2012, 09:26:23 pm »
After replacing the battery it loaded right up no problem. It still doesn't see the card reader and it wont start unless I use the button on the front of the tower.
ed12
« Reply #203 on: August 05, 2012, 09:52:27 pm »
hi
dirt
ok good we are back where we started :) i must admit u had me concered
let me recap so i get the fact's right
u have 2-x card reader's ?
both doing the same thing
but if u use the start button the game will do it's normal bypass and carry on properley ???,play a game or 2 and let's c if there are any other hick up's
we can test the reader on a normal putter by loading the nessary driver's into the :host:,and plugging in the unit to the new :host:
that would be my next move
ed
dirt
« Reply #204 on: August 05, 2012, 10:07:54 pm »
Yes after i hit start it plays as normal. Ill play a couple games and see if anything weird happens. Ill start a game now. Yes I have 2 card readers and both do not show up.
dirt
« Reply #205 on: August 05, 2012, 10:59:56 pm »
hi ed
i just played a few games and everything seems normal.
ed12
« Reply #206 on: August 05, 2012, 11:21:58 pm »
hi
dirt
thats great
now if we plug the card reader's into
any window's xp usb port
it should report
found new hardware :stc-11-sdk device:
let's try that with the 2 unit's in q and c what happen's
rem to shut off the first 1 if it detect's before u try the second 1
this will narrow our range down,.. do u have a usb mem stick or a usb keyboard laying around ?
ed
dirt
« Reply #207 on: August 05, 2012, 11:39:23 pm »
I just walked into the gameroom and the game is frozen. The led topper is still normal but the game is frozen and the buttons do nothing.
ed12
« Reply #208 on: August 05, 2012, 11:49:09 pm »
hi
dirt
video card or ram
reset game,ie shut down count to 10 restart
with putter >game putter open < 1 side , wait a few min's
and just touch for heat,video card is first,ram is second
make sure the fan on the video card is working at all time's
if someone just replaced it,then that is your problem
get back to me
ed
dirt
« Reply #209 on: August 05, 2012, 11:57:22 pm »
I turned it off. And when I turned it back on its back to nothing but the long beeps.
dirt
« Reply #210 on: August 06, 2012, 12:04:21 am »
I felt the heat by just opening the back door. Ill check the fans.
ed12
« Reply #211 on: August 06, 2012, 12:21:17 am »
hi
dirt
heat on these unit's is a bugger
it can do alot of damage fast
chk all fan's
inculding the aux switcher used for 12 to the dba <digital-bill-adpater>
and coin door and the 5 to sub system's,it should be located at the front of the cab,is a normal putter switcher,also chk the heat sink of the micro,if need be
remove fan and housing alummin and re-heat-sink-lube-it,and put in new fan's
all around,forget cleaning them as that is a patch at best
ed
Spitfire
  • Last login:August 05, 2023, 07:55:31 am
« Reply #212 on: August 06, 2012, 12:57:13 am »
Hi Ed this sounds very exciting, now if only u can instruct me on how I can make this happen please? My machine is a team challenge with an upgrade kit all access pass it says. This gives me a few more courses than normal as my cousin has the normal team challenge machine. I also have players cards n 1 operator plus card n as previously stated would love instructions on how to unlock all players courses items tournament online etc. let's start with unlocking players courses.
Can u please provide step by step instructions this would be greatly appreciated?
Thx Joe
ed12
« Reply #213 on: August 06, 2012, 01:36:21 am »
hi
spitfire
the ins. u are after is perty much straight foward now that u have answered 1 q
op card...with it the new.cfg/.dat that i will put toghter, will go in seam-less.
it does in into hercules and replace's the orignal,the demand and u will c it is that it make's a back up .dat of the original .dat,this must :must: be put in it's own .dir
it is a command in the .dat i will not un-lock at all do not ask..
as far as turnnie goes i am north of the border,u should beable to hook to gobal-vr's net. in the usa ?,there hub is in the great windy city
ping it,if not u can set a few bud's up,using your unit as the server head,u will need ram..512k is just not enough,plus a new asus mirco would not hurt with a wack of ram so u have buffer to play on line,vpn require's a min of bandwith
and ptp is the best way,your machine must stay on at all time's or :server: link
is lost.it is coded to use 2 reader's read it 2 1=op 1=player = u
op must must be in there at all time's or u crash the system,all dat is saved in your unit,so u see where a rather large storgage device is handy here,no i have not coded into cloud so if some one want's to chime in i am all ear's:)
dial up is rather slow,straight dsl is good enough,wireless 5g is best for now
we could do 802-11-g/h/new-z any of them can be coded in
u must pick as the .dat call's for it and will expect it.
once i upload the .dat it come's with a brief how to,follow the short set of how to's
u are just about there...it will ask u alot of q's have your pen and paper handy
u will be writting down alot of #'s.,they must be put in and saved
ed
Spitfire
« Reply #214 on: August 06, 2012, 06:27:26 am »
Hi Ed
Thx heaps for this response this all sounds great n wish to proceed as instructed to get things happening. Am I right in saying that you will supply me with a new cfg file n new dat file that I need to add to my system. If so please instruct how u will get this to me n what I need to do to make this unlock new players courses items etc.
In regards to the tournaments I am in Australia n not sure if I will be able to hook into the USA server without any lag however I can try. Also are you asking me to change pcs in order to make this run locally. If so I have a few Acer core duos 2.4ghz handy which I can use with 4gig ram. Would it be just a matter of swapping out the hard drives n plugging everything to the new pc including the dongle. Will this work?  If so then would love to get it set up with ur help and instructions. Please let me know exactly what you need me to do Ed?
Thx heaps ,
Joe
CVN53
  • Last login:December 24, 2013, 10:33:27 am
« Reply #215 on: August 06, 2012, 10:17:42 am »
Hi Ed
 Have you got the dlls from your co coder so I can get this game going again?
Thanks CVN53
ed12
« Reply #216 on: August 06, 2012, 11:30:50 am »
hi
cvn53
i will bump the coder tonight
have not seen him for a byte ?
maybe he took a few day's off ?,it's alright i have not forgoten
spitfire
ok u are aussie,let me do it it this way
i will set the control.dat to a max of ten
the olny reason i asked u to ram up
is u may end up beening the server
if u share as with most vpn's then 1 gig is good 2-x-512=1gig
i may want u to up the harddrive though ?
i have 1 here i will run the turrnie on it tonight
and see
ed
ed12
« Reply #217 on: August 06, 2012, 04:57:44 pm »
hi
bios
enable onboard lan
enable onboard bios for lan
find it's ip
if u cannot,post i will show u how
on side with acrade control's now :on-team-challange-golf:
on boot :delete:
bios screen will pop up
go to what i posted earlier
enable both
u are now server
in windows click :start:
stop task
click new task
open desktop
click win internet experoler >net< not your box
click internert explorer,wait,set :tool's/optiton's/default<<apply>>
colse,reopen,bang u are ethernet on the web
type in google just to set your mind to rest
it will go
game will shadow in the background >ram-here-is-needed<
next we set ip's that are allowed into your box >this is important<
as u are as your buddy's will b
 acting like a server,so u MUST colse the door to snoop's
private network ie vpn
next we snap our ip's,which in your case if u are high speed ? will be dchp
so we will need to asign a .net code >front door< and auth password..
this is where hercules come's into play
we write the command .dat
so pick your # of ppl or i will set it to a max of 10 ?
with the op card if all ten have it u can rip in as many change's as u wish
u :must: need the server front end,i will up-load,i am  just hammering out a few winblow's glitch's
there u go spitfire
dirt how did u make out?
ed
Spitfire
« Reply #218 on: August 06, 2012, 07:08:11 pm »
Hi Ed
I am very excited to get this up n running. I will follow ur instructions n get everything set up ready for ur server front end. I will let u know if I have any problems. Thx heaps Joe
Please let me know if u need me to do anything else
ed12
« Reply #219 on: August 06, 2012, 10:45:55 pm »
hi
spitfire/dirt/cnvs53
start game as per my  last set of ins's....
enable lan/enable boot-room for lan
save colse
next >important<
start game as per normal >power-down-power-up<
keep pressing  :f8: to get u to safe mode
now here is the tricky part,do not do not go to full safe mode
go to safe mode debugging
spitfire
 this part is for u
>then start/control panel/internet properties
once there click connection's
u will see the add dial-up/virtuial private network connection's
THIS is where u ADD the IP's i spoke off >network-share<,they MUST do the same
if they are running a firewall then they will need to add the base ip addy<
cnv53
same but skip the upper step as that part is to turn on sharing
 u will c nvida nview it should read your new card sticky ie ati etc
which mean's window's got it
then colse out
go to c:/program's/window's/team challange/hercule's
there u should see 3dfx,this is ok
go to hercule's
add this command line when i post it
u need not delete anything u are just adding and saving
wa la u have video
dirt
go to system chk the status of the ram..etc
ed
dirt
« Reply #220 on: August 06, 2012, 10:54:33 pm »
I wont be able to get to it till tomorrow. I have family over tonight.
ed12
« Reply #221 on: August 06, 2012, 11:11:10 pm »
hi
dirt
ok tommrow i am a tad 50/50
as i am going to be all over doing s-c's
but i will answer
let's put this 1 to bed
ed
Spitfire
« Reply #222 on: August 06, 2012, 11:36:47 pm »
Hi Ed
Trying my best to set things up as you suggested. My bios is all setup as u require. Now looking to setup VPN in windows. It asks if I want to use my smart card for this connection do I say yes or no?
Also not sure how to get into windows while game is loading? I clicked the start button but game kept loading so I hit control alt delete n stopes game that way. I then loaded I explore.exe as open desktop didn't work under new task as per ur instructions. Also needing to run a LAN cable to the machine unless a wireless dongle might work??
In the mean time can you advise me on how to unlock all players n courses as I see they are all there on my system so I can enjoy them until we figure out how to play online against my friends.
Thx once again Ed for all your help.
Joe
ed12
« Reply #223 on: August 07, 2012, 12:28:56 am »
hi
spitfire
f8
will take u to windows safe mode in start-up
u just keep hitting it until windows answer u >this is safe mode defualt cmd<
windows must answer it.....
from there u go start
and follow what i stated
ie start/control-panel/internet option's/connection's/setup/add/the ip's u want to ping into u and u into them,that is vpn,we then tell herc that it is lan :not dial up:
as hercules clealy show's a dial -up connection in it's .cfg this is under :connexict:
we just change that to our new :ethernet:
invoke other course's c:/gobalvr/add/player's/def table.....ie where they are and who they are...
u must define each and every 1
i am on the side of safe mode right now
ed
Spitfire
« Reply #224 on: August 07, 2012, 09:03:07 am »
Hi Ed,
Follow what you said n used f8 to get into windows I am able to set up vpns. Do I set up one for every ip that will link to my machine including one for my machine? Awaiting ur instructions and the file uploads to make these tournaments happen.
Also couldn't find c:/gobalvr/add/player's/def table as you suggested on my system. Do I have to create these folders n if so wat needs to go in them to unlock all courses players items etc. I can see folders of different players n courses would do much love to add these to my game. Please instruct how I can do this as I am desperate to have them unlocked.
Thx heaps for ur patience Ed just can't seem to understand wat to do n I guess it's all very easy in ur eyes lol
Thx Joe
ed12
« Reply #225 on: August 07, 2012, 11:40:25 am »
hi
spitfire
u add ip's u want to ping into
the iper's >there end< must also do the same
i am chking to see if u have to spec your's in your own machine or not ?
as u are dchp i  think not,but i will not stamp as such until i run some routing test's
tonight,the player's and course's are clearly marked where i said they will be,u can
expand on them :ie-add: just keep in mind there atrabuite's when saving them
ie the same >.extenision< as the other player's and course's,we still have baby step's to take before we fully invoke online turrnie play,ie we need to set herc
for lan instead of dial-up,we need to kill the dial-up and add our own ip-.cfg to herc
dirt
i did the test's,your onboard usb should handle the card-reader
sorry if  i caused confusion and had u spend money u did not have to :(
but all of the pga's i have expect the test 1 use's a exp. card
so i was going by feild exp,forgetting i had redone my .cfg in this unit
to do just that
ed
dirt
« Reply #226 on: August 07, 2012, 12:23:02 pm »
ok. i got the usb card cheap so thats no problem. the usb card does work as i loaded the file you gave me with a flash drive before the puter shut down. if the mobo usb can handle the card reader then it must be a file or something wrong because the mobo and the card dont see the reader, or both my readers are bad. i bought the second reader as tested good but you never know. im going to get to the machine later today and ill post what i find out about the fans and ram.
CVN53
« Reply #227 on: August 07, 2012, 03:12:27 pm »
Hi Ed
I found nvidia nview nothing happens when I try to open it, I hve no c:/program's/window's/team challange/hercule's.I have pga tour golf 2005,gvr,hercules,gvrplus and these are folders in C:\ . I did a search for 3dfx on PGA C:\ nothing found. PS Name of my game is PGA Tour Golf Challenge
CVN53
« Last Edit: August 07, 2012, 03:27:09 pm by CVN53 »
ed12
« Reply #228 on: August 07, 2012, 03:33:57 pm »
hi
cvn53
this is a green board or red correct ?
>Hi Ed
as thats how i c it
if so this is made by :it's gamming:
and if so u will need to use ati >green-video-card< and or red nivda
of eariler verision
to open there hard drive i will need to boot to linux
as the video is  controlled by a=eprom and b=pgl chip
it is perty much hard coded in
but all is not lost if this is the case as i have crossed over many of them
to other video card's
pga golf by gobal vr dose have the forementiond .dir's exposed and u can edit at will
ed
CVN53
« Reply #229 on: August 07, 2012, 04:20:49 pm »
Hi Ed
 The video card is a red card if that is what u mean
CVN53
ed12
« Reply #230 on: August 07, 2012, 04:35:02 pm »
hi
cnv53
i am refering to the main board
if it is a 2005,then this is a it's gaming board
red or green,gobal vr is a stand alone putter
please clear me up and i can better guide u
ed
CVN53
« Reply #231 on: August 07, 2012, 06:04:57 pm »
Hi
Ed
Its a green mainboard,its a intel board Rev. B is all I can see.Where are the .dir's located if they are exposed or is that in linux.
CVN53
« Last Edit: August 07, 2012, 06:12:41 pm by CVN53 »
Spitfire
« Reply #232 on: August 07, 2012, 06:58:47 pm »
Hi Ed
Thx for reply. As I said previously I don't have those folders on my c drive. I can see players names and courses elsewhere in a few different places but please explain step by step on how to add them to the game? Do I need to add code or something? Please explain the steps for us not so smart fools ha ha
Thx Spitfire
ed12
« Reply #233 on: August 07, 2012, 10:43:43 pm »
hi
cvn53 give me a few here
i need to chk something,maybe u could up-load of pic. of this unit ?
spitfire
ya i will do a walk through
it's easy enough once u do it a few time's
but if u have never done it i can see where u can become confused
u will also need a walk through to invoke the :lan: as it is a tad more involved
i will suggest u print both out and keep them handy until u become more flunet
in this..>no dis there mate<,turn's out i need to write the complete .exe file for the lan so that will set me back a day,i kust may brute force it,but i am not sure if it will stick..i have my network set now so i can test tonight
ed
CVN53
« Reply #234 on: August 07, 2012, 11:44:01 pm »
Hi
Ed
Here is a picture of motherboard, I think it is a NB32-SL, Lga 775 socket and its a DFI case.
CVN53
« Last Edit: August 07, 2012, 11:47:55 pm by CVN53 »
ed12
« Reply #235 on: August 08, 2012, 12:17:56 am »
hi
cvn53
thk's for the pic
ok i will dig your path out for u
it will c:\let me dig here
ed
Spitfire
« Reply #236 on: August 08, 2012, 01:26:32 am »
Hi Ed,
Eagerly awaiting  those walk through n yes I will print n keep handy. As I will need to run on my friends machines also. I will look into my c drive tonight n post the folders I have in it if you like. However with the step by step walk through to unlock courses players etc I think it will become clearer which folder you want me to go into. Still need instructions though on what to do once there to unlock things to bring up in game. Thx spitfire
ed12
« Reply #237 on: August 08, 2012, 01:53:33 am »
hi
spitfire
if u click a mouse as per my inst on to invoke window's with pga shadowing
in the back-ground,but the game running in reg mode,i know that sound's strange
but the point here is to invoke/mouse/window's control over the game,which u would have if u fowlled my ins >with-out-re-booting<,as the game will default to normal,from there,u will beable to see pga 2006 or +,if u look at the file ext's it want's to open they are olny anark media file's >this is how the eng's of gobal<
hid the file's,we need to add a window's call for all knowen file type's,no bigie here
it just a few .dll's
cvn53
do me a fav and set your hard-drive to slave and pop it inside of your home tower and or an external,rem your last jumper setting as it just might be cable select,and will need to go back when we are done
from there depending on the box u are hooking to it will be
EXAMPLE HERE c:\pga\hercules in there u should see 3dfx
it should show up as pga-->>drive<< hercules,then u should see nividia >video driver pack<..we need your new video card id there and in hercules
for the 3 of u spitfire/cvn53/dirt if u all can remove the harddrive and do it this way
we can better get to collective goal's
thk god for sqxml i never thought i would say that as i do not like sequeal server
but it's there and hard coded in i see no reason to redo it
spitfrie i am doing this on a running pga team challange
in pm shortly i will be giving u my ip and asking for your's as it will be a test
to make sure i got my ### right,then she's all your's
ed
Spitfire
« Reply #238 on: August 08, 2012, 06:56:16 am »
Hi Ed, I did as you have instructed using f8 n had the game running in the background n yes I do have a Pga 2006 folder also many others. However couldn't find the globalvr folder n it's subfolders u ask me to goto to add new players. I have a gvr folder gvr plus folder but no subfolders matching ur description above. I will wait until u have everything ready to go to be able to add/unlock the new players courses n items etc n also the online tournaments before I go changing to much as I really want to continue playing the game as I fn love it ha ha. My email is js@soccerproacademy.com.au if you need to send me any files or instructions once u have them ready to go. Thanks once again Ed for all ur work. Thx Joe
CVN53
« Reply #239 on: August 08, 2012, 05:57:47 pm »
Hi ED
I have slaved PGA and there is no PGA folder in C:\ in hercules there is no 3dfx,also in C:\ there is a Nvidia folder here is a list of folders in C: Drive- Folders are ATI,Doc&Settings,gvr,gvrplus,hercules,Nvidia,pga_tour_golf_2005,Program Files,rescue,rescue disk,tournment and windows.In hercules all I have is alot of exe's,stopall.bat,us2_dismiss.wks and coin_drop.wav. PS-PGA is the name of C drive
CVN53
« Last Edit: August 08, 2012, 06:39:39 pm by CVN53 »
