Author Topic: Linux+tvout  (Read 4571 times)
Dillthegreat
  • Last login:July 18, 2002, 10:04:34 pm
  • I want to Build My Own Arcade Controls!!
Linux+tvout
« on: June 16, 2002, 10:54:12 pm »
Hello
im using linux as my base os and using pycade for my multi-emulated frontend
but i wanna know to all those linux users that are also using tvout for the cab
whats the best card , also can you run tvout from bootup straight into linux
without a monitor ?
« Last Edit: December 31, 1969, 07:00:00 pm by 1026619200 »
Jakobud
  • Last login:Yesterday at 10:09:01 am
Re: Linux+tvout
« Reply #1 on: June 17, 2002, 11:55:29 pm »
You just need to get a video card that supports full tv out without the need of software.  Just get some sort of GeForce2 card.  It will be enough.  I'm using an Asus v7700 I think.  It has SVideo out.  Yes, it can be used without the monitor.  When I turn on the computer, it shows everything on the tv, even the bios bootup.  But don't go too cheap.  Try to find a GeForce2 card with a Chrontel (brandname) tvout chipset on it.  In my experience, that has been the best tvout chipset for that pricerange of card.  I believe that 'most' of ASUS's cards use Chrontel chipsets in them.
jakobud
  • Last login:Yesterday at 05:41:55 pm
Re: Linux+tvout
« Reply #2 on: June 23, 2002, 02:28:29 pm »
i can't believe i didn't see this post sooner.  Not geforce, ati!
Bad, Jakobud, bad. ;)
Seriously, ati's always give better tv-out than geforce and they work without software as well.  This is merely an opinion but I worked with both brands on a daily basis at work, so i could literally have side-by-side comparisons.  Ati always looked slightly better.
